SMOT - Close to closing the loop ,second video-BIG improvement
Started by billmehess, March 31, 2011, 01:05:30 AM
Low-Q
Quote from: Poit on April 02, 2011, 05:21:46 AM
noo... it is not repelled by the magnetism, it is repelled by gravity as that part of the track is tilted upwards.... trust me, the entering of the gate is no problem, the problem is exiting the gate (with out assistance from gravity).
OK. I thought the glassplate was straight with no curves. Sorry.
billmehess
What a great site this is . Thank you for all the feed back! Buy the way I picked up another 1/8" last night so I am 3/8" away. This is less than the diameter of the ball which is 1/2". I did this by tapering down the 1/2" walls on the receiving uchannel at the enterance and adding additional magnets to pull the ball into the SMOT.
We may all argue a little but I respect everyone here!
gyulasun
I am not sure that energywise there is any difference between going on Low or High road for the ball (I know you did not claim such) but using the flexible tube that ends at just the entrance point of the smot ramp seems to give one more chance for testing to close the loop.
The curved path giving a time advantage versus a straight one was discovered by Galileo, see this interesting link:
http://www.sewanee.edu/physics/TAAPT/TAAPTTALK.html
I repeat: it is a good idea to use a clear flexible tube for this smot test. Use a tube with higher enough diameter than the ball so that inside air would not cause energy loss (make some holes on the top of the tube too).
Gyula
mscoffman
It might be worthwhile to have a length of cast iron
pipe. They used this in city-gas, compressed air and fire
sprinkler distribution systems. This may be of use to
isolate a steel runner (not a magnet) from the influence
of external magnetic fields if the runner misbehaves
and it is not at an end. Just heat the plastic tube
and slide it over the iron pipe and do the opposite
at the other end. The external mag field should flow
around in the body of the pipe leaving the ball inside
alone to roll on.
:S:MarkSCoffman
