SMOT - Close to closing the loop ,second video-BIG improvement
Started by billmehess, March 31, 2011, 01:05:30 AM
billmehess
Monday 12:00 am I have closed the distance between the entry level uchannel and the
plate to 1/4" which is 1/2 the diameter of the SMOT ball.
gyulasun
Quote from: billmehess on April 04, 2011, 03:06:25 AM
Hi Bill,
Very good news, I am looking forward to your fully defeating the rest distance too.
Earlier you mentioned a drag-free solution to induce some mW power for flashing a LED (or whatever) to demonstrate the smot is able to produce some extra 'juice'  (besides moving around the mass of the ball). How is it done I wonder.
Thanks, Gyula
billmehess
On my next video I wall show the SMOT producing voltage. It will not be lighting  a LED though as this would require around 2 volts. I will be showing a capacitor charging up.
The SMOT device is very  scaleable for increased energy production. There is NO load on the ball.
I am down to my last 1/4"
mscoffman
@billmehess,
Good work so far. One thing you may want to have on hand, if
your device works is some 3M Antistatic spray, Cautiously applied
to the plastic tube. Apparently these kinds of device can generate
a static charge, potentially increasing unexpected behaviors. You
want the runner ball to go around, not necessarily having your
setup lifting off. :-)
billmehess
Quote from: mscoffman on April 04, 2011, 02:51:51 PM
@billmehess,
Thank you Mark  as usual your input on a subject is worth its weight in gold
