Lenz's law can be violated.
Started by EMdevices, April 09, 2011, 08:19:16 PM
pese
Quote from: nul-points on April 25, 2011, 01:04:10 PM
hi Gustav
kudos to you for inventing the reverse silicon transistor oscillator!
please note that i mentioned "Negative Differential Resistance" - not true 'negative resistance'
all the best
np
http://docsfreelunch.blogspot.com
Sure, i done this. you must not ask me again.
My own company have worked over 40 years with semiconductor. , for industrial use, also export to us and asia.
i find this out because it give before the silcon eptaxial transistors an lot of silicon point-contact (in german "kegierte" semiconductors (know not in moment the exact englisch word.
This transors wared in bothe direction (als recers !  , some Symetrical with same gain. Normal type habe 1/19 of gain in reverse.
So i have find out - becaus we have selected , and selled "bad" transistors as (for) zener diodes (Emitter-Base reverse Diode)
6-20 volt, also Power types as 12V 4 Amp in To-3 case !.
so , the Transistor (we take BX 107 and others. in reverse with oben base, will work  als an Transistor, bute the maximal voltage ist only 9m7 volt over the b- e- way.
so the additional 0,7 volt between  c-e (in revers, will mahe the open base "leding" if ce c-e becomes about 0,1ma current.
on this highest voltage point, the open base will become an internal corrent and ist als "amplifyng" with 1/10 of the  normal gain).. so it follow an amplifying with degreasing the
c-e voltage, bat nit to zero ! only low to the about 1 kot lower zener voltage be.
That ist all.
Only about 1 Volt this "ensemble can work.
this only at a starting current at about 0m1ma.
and only by the voltage from about 0m7 volt over the e-b zener-voltage of the transistor.
NOBODY have or can explain this WORKING of this (from popular electronic "named" NEGISTOR.
yOU READ THIS AND LEARNED THIS NOW AT THE FIRST PERSON !
My invention of this was given as an frequency generator "sawtooth genarator" about 3 years before the popular electronic, have uses this also  for more uses.
Pleas se on Scope, It is nothing else as sawtooth.
nor sine nore square. like neon or trigger.
any lamda or tunner diode have other characteristics !!
It have the same working as trigger diodes , neon, bulbs
but with lower voltage swing differences (low to peak).
Be sure that i find in my live more details and circuit to use semicondutors in unusual ways.
If you will use this circuit above, like an negative restance,
you can do this, in the way als with any, tunnel lamda trigger diode it is possible.
Nothing more
Pese
ramset
Pese
Apologies for interupting!
I tried to login at Stefans German Forum But It doesn't recognize my Name there
We have a man sharing a Gravity device here
http://www.overunity.com/index.php?topic=10661.msg283024#new
Helmut from Germany has been involved with these before,
Can you get word to him please [and anyone else there thats interested.
Chet
Thanks Grandma
nul-points
Quote from: poynt99 on April 25, 2011, 01:18:51 PM
I disagree that this would show proof that PM's can do work.
that's ok - you're entitled to an opinion, just like everyone else  :)
However, I would be interested to hear your explanation as to why** you think this is so?
.99
** the conditional conjunction in para 1 and the content of paras 3 & 4 of that post should give you some clues
nice work on the Ainslie cct reduction btw!
np
pese
Quote from: ramset on April 25, 2011, 06:24:12 PM
Pese
Chet
Hi Chet.
for overunity.de you must "instrive" you separatly (again).
i am most in  . de working,because its my native language, but here , i see an wider range of interests.
possibly only 2-3 persons will have interesting on gravity, bessler and so on ...  Helmut, it is sure, he is interested on
such devices..  i can let an "note" to overunits.com , if you
preferre this
Gustav Pese
here you (all) find an collection of alternative links that i collected since near 10 years.
www.alt-nrg.de/pppp  (german and englisch link collection)
nul-points
Quote from: pese on April 25, 2011, 05:58:58 PM
Pese
yes, i have a copy of the PE article - it was largely responsible for getting me started looking at FE
my early experiments involved multiple connected 'negistor' oscs
very interesting behaviour!
glad to hear that you are active in the FE field also
good wishes
np
