mag-gravity
Started by FreeEnergy, May 30, 2006, 03:50:44 AM
FreeEnergy
gyulasun
Hi,
Would you mind describing your setup a little ??  For me it is not self-explanatory, sorry.
On the upper left you have a magnet, indicate the poles please; is it a quarter piece circle magnet? If so it is hard to obtain?
Gyula
FreeEnergy
as the 'metal' gets attracted to the 'magnet' the arm rotates to the bigger end of the magnet then it flaps close (with the help of gravity) and the magnetic field is decreased while there is already another arm starting.
kind of like
http://www.overunity.com/index.php?action=dlattach;topic=751.0;attach=734
http://www.overunity.com/index.php/topic,751.0.html
only thing is my design has a flapping mechanism to decrease the magnetic field.
gyulasun
Thanks for the hints.
The only thing I cannot get now is: Why your flapping mechanism is supposed to decrease the magnetic field when the non-magnetic arm closes ?? What material do you think of? Have you done tests with that material?
Because if that material really "absorbes" flux as if it were a flux "screener" and the metal sees less flux behind that material, then your idea has the possibility to operate as you planned.
Gyula
FreeEnergy
Quote from: gyulasun on May 30, 2006, 06:23:33 AM
Gyula
the arm (can be anything non-magnetic) flaps close on top of the magnet, see i know you cant completly block the magnetic field, it just needs to be decreased to some extent.
the flapping arm can be real thick and light weight
no tests just ideas
