A Test to Prove Gravity Has Mass
Started by brian334, June 01, 2011, 04:39:08 PM
onthecuttingedge2010
So, a black hole is a pushing system???
gravityblock
Quote from: onthecuttingedge2010 on June 02, 2011, 03:38:08 PM
No.  There is a centripetal force or pressure within the universe.  Wherever you place yourself in the universe, you will experience an equal pressure from all directions, thus you would have no movement on your own.  Only an external force can impart movement to a body.  When you place a massive body near your location, then this massive body interferes or shields you from this universal pressure in one particular direction, according to it's density and volume.  This causes a net force to be applied from the other direction which causes this universal pressure to push you towards the larger mass.  The black hole or a large mass isn't responsible for the pushing.
GB
brian334
More bullshit posts that do not have anything to do with the topic.
AB Hammer
If gravity is a pushing force then a black hole would be more like a sink drain to another dimension or parallel universe.
QuoteWhen a particle moves thru something that has mass, some of whatever the particle is moving thru is moving with the particle. When said particle makes a impact the force of the impact will be a combination of the mass and the momentum of both the particle and whatever it is moving thru.
So if gravity does not have mass than the impact force of the particle will not change in different gravitational fields. But if the impact force of the particle does change in different gravitational fields than gravity must have mass.
brian334
6/1/2011
Brian334
For this test you will have to have a partial free location. So I have to ask is it even possible?
Alan
Alan
I am sorry but I don't buy into this gravity being a pushing force. no reputable scientist would either.
