Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
0 Members and 23 Guests are viewing this topic.
protonmom
Hi Pomodoro.  I agree with you, which is why I suspected the ebay seller of ripping me off.  However, the other rods which I have not yet used (same order from seller) are very brittle.  This one that turned rubbery, seemed brittle too at first.  As of today, it is still in the rubber state, and I have not had the time to do anything more with it.  I wish I could find that ad from which I bought the rods so that you all could be forewarned.  Unless something "magical" is happening (which I doubt) to turn these into rubber consistency, then someone online is getting rich ripping off their customers.  I cannot see how I could have produced enough "heat" needed to "melt" the ferrite.  But I intend to continue experimenting as time and health allows, to see if there is anything to it.  Thanks for your input.
Eniac5state
 I am very dissapointed in the people here. You didn't do any homework on pyramids !
And how to get basic results fast. First Egypt is totally hot and dry.
Is your place ? You have no basic knowledge. You have no basic knowledge.
K4ZEP should be ashamed of himself. He knows that an electronic crystal should
not be short circuited like he does !  What school have you been ? So use plastic
tubecaps for this. And a German in the other forum explained that the real pyramid
doesn't use any metal sides since this dampens all oscillations. Why does it always
have to be Germans who do the technical developments ? And don't loose yourself in
understanding of swr. This takes years of learning. Just look at the basics without
the will to understand it all. Yes you can lightup gastubes with this like the egyptians did
This tech only needs free high voltage. Just copy this unit in your garden:
www.youtube.com/watch?v=7vMT-9rW5Lk#t=6.229047  Look at from the 4,5 minute.
Be responsable. if you make this too big it will be dangerous.
vern
Hi all,
   I started building  TT's pyramid two years ago but was interrupted by life. I had everything ready, I just needed to figure out the process of hi voltage and high frequency when adding the quartz sand as I did not have a CB or any other way to induce it.
I have not read all the posts in this thread and was curious if anyone had actually built a scaled down version of the pyramid for measuring possible energy production using what recently new evidence suggests as agglomerated limestone. As far as I know everyone has used other materials for the frame including myself (copper). Just a thought...
Melody
Hi Peoplez,
I have been following this treath. Also the video's of Trawoger. In the beginning it looks promising.
But I find it hard to believe Trawoger is a lyer.
So I found out that you all made a different pyramid than Thomas did.
Someone mentioned before:
Thomas says the coils have to be winded the same direction.
But I see in his video's that the inner coil is winded in another direction than the outer coil. Just see it in the video's!!!
So he made his coil different.
IS THIS THE FAULT / MISTAKE EVERYONE MAKES ?
Is there anyone who still has the pyramid ?
I am very curious about this.
Please let me know if it helps!!!
Yours Sincere,
Urias Nooteboom
Holland
