Why do two drive coils draw less power and create more RPM ?
Started by DeepCut, July 04, 2011, 03:20:26 PM
yssuraxu_697
DeepCut, you do not need diode for each coil when they are in series.
If diode is a bit underpowered you can put multiple in parallel.
Also making all coils as similar as possible would be good practice.
Magluvin
Im at lunch
So I assume you have all the diodes facing the same direction in the circle of coils. If some are wrong, the drive current will go through the diode and not the coil, thus increasing current and slowdown.
If all are correct, then I suspect some diodes are shorted.
I am doing this as we speak, with 3 coils in series and 6A diodes(RS) across each coil and I get the increase with each and no problems.  You can try 1 diode across all coils as a whole, but the diode may have to endure higher voltages.
I suspect you have a few bad diodes or the current/voltage limits of the diodes are being breached.
I can show a simple vid later after work.
I have no doubts that this works 100%   ;]
Mags
DeepCut
Thanks yss and Mags.
I tested the diodes and they are working and they are all the right way around, they all come up at around 700 on the multimeter diode test.
These are them :
http://www.datasheetcatalog.org/datasheet/surge/1N4004.pdf
Is the spec not good enough ?
I'm thinking since the only coil that works regardless of which diode i use is the coil with the least turns then maybe the others have too many turns on them ?
Magluvin
Hmmm
doesnt make sense..   I would very quickely try the other coils with the diode in the opposite direction, just for sake.  Do you have a pic of the setup so I can see when I get home later?
If you dont get it , ill be back on this evening to see  what is up.
Are the coils that different from each other?
Something is strange..  My coils are beefy.  .44ohm 18awg 2.5in dia 1.75 thick  around 2mh  in series. I do the diodes when in parallel also..
This is a way to get more to the rotor by using less than normal. We could capture the excess, but instead we are applying the extra into getting more motive force to the rotor that the gen will work with.  Its all about doing all we can to increase efficiency.  ;]
Mags
DeepCut
Three of the coils are 800 turns bifilar, trigger wire is finer than power wire, can't remember gauge maybe trigger around 0.25mm and power 0.35.
The fourth is about 600 turns of same.
My generator cores arrived today and they are the wrong bloody size, my fault, i was going on bolt diameter not shield diameter ...
Here is pic :
http://qvision.pwp.blueyonder.co.uk/setup.JPG
I have a callout so won't be back until 10pm.
