Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
synchro1
JLN has looped a Lenz delay circuit and charges his run battery while underload! Note that he accomplishes this with merely two coils like my self loop OU Diametric spinner.
http://www.youtube.com/watch?v=dMjHNJEuzHw
gotoluc
Quote from: synchro1 on March 17, 2013, 12:26:22 PM
Hi synchro1,
thanks for posting JLN new test. I don't want to sound negative here but I would like to point out that JLN new test is not a self loop. The input to his prime mover is from a power supply set at 29vdc and 3.12amps = over 90 watts.
JLN is only demonstrating that the coils under load (one on the LED bulbs and one charging a battery) will not affect the prime mover.
JLN needs to find a prime mover that is much more efficient then the outrunner motor he is using to consider a self loop.
I'm glad he is doing these experiments as it may encourage others to research.
Luc
synchro1
Quote from: gotoluc on March 17, 2013, 01:06:58 PM
Hi synchro1,
Luc
You're right, thanks. He'd get the self loop OU if he positioned a diametric tube magnet snugly in the output coil core, and replaced that juice hog motor with a large tube spinner like Skycollection's.
DeepCut
Here is the link to my virtual coil builder program :
http://www.mediafire.com/?op72vvb361ovw80
and here is the link to the BASIC language compiler that runs it, scroll down to the BlitzPlus item that is free :
http://blitzbasic.com/Products/_index_.php
The program can be set to go for a resistance target or a number of turns target.
It then reports the coils dimensions as well as projected properties like inductance and resistance.
I have checked nearly 20 actual coils now and have also compared it with online calculators and i'm very pleased with it, the inductance calculation has been within around 3% accurate.
It has saved me from shooting in the dark and i can now confidently wind a coil having first simulated it to see the perfect coil-former length and diameter to maximise its inductance, i hope it's helpful to others.
DC.
