futuristic
Quote from: teslaalset on September 05, 2011, 06:36:01 AM
I even doubt coils can be made that effecient they will leave a surplus of torque when loaded.
Toranarod on 08-03-2011 got more RPM with shorted coil than without the coil at all:
http://www.energeticforum.com/renewable-energy/7982-muller-generator-replication-romerouk-35.html#post149807
kEhYo77
Quote from: teslaalset on September 05, 2011, 09:02:47 AM
This means a compensation capacitor value is dependant on the mechanical load.
Yes, it is, so the RV capacitor should be selected after finding optimum speed for the effect to manifest and then at this speed we short ALL
the generator coils or put them on a specific, constant value load and then, under this condition we try to select the right compensation capacitor for the RV motor.
This setup should be much more efficient then.
teslaalset
Quote from: futuristic on September 05, 2011, 09:17:26 AM
If that is true and it can be replicated he is on the right track.
I wasn't aware.
Thanks for the link.
I will study this.
futuristic
I'll try to replicate it too. I already have DC motor and 10mm x 10mm neo magnets. For core I'll use mumetal from hard drives.
teslaalset
Quote from: teslaalset on September 05, 2011, 09:33:39 AM
Ok, I had a look at Toranarod's data.
Yes, indeed he seems to have higher RPM with a generator coil, compared to the situation without generator coil.
However there is also a motor coil present.
Unfortunately he did not monitor (or post) the data on the motor coil.
The used power of the motor coil is also relevant for solid evaluation.
So, incomplete data unfortunately. Still no proof of concept.
For some reason I can't post messages on EF although I have a valid account.
Can somebody post a question to Toranarod to provide also the input power of the motor coil, to complete his table?
