CRANKYpants
Quote from: Overunityguide on September 16, 2011, 04:29:15 AM
Dear Thane,
Maybe what you can do when you have finished the Kinetic Bike, is to let any of the critics spin around on it and let them accelerate until they are crapping their pants. :)
With Kind Regards, Overunityguide
For Information about the Confirmation of the Negative Lenz Effect:
http://www.youtube.com/watch?v=kzxc3Ai4T3A
DEAR OVERUNITYGUIDE,
FIRST OF ALL THERE IS A VERY BIG DIFFERENCE BETWEEN A CRITIC AND A CYNIC
cyn·i·cal Adjective/ˈsinikəl/
1. Believing that people are motivated by self-interest; distrustful of human sincerity or integrity.
2. Doubtful as to whether something will happen or is worthwhile.
CRITICISM IS POSITIVE AND CAN BE CONSTRUCTIVE CYNICISM IS NOT.
HERE IS ANOTHER CONFIRMATION FROM SWEDEN:
http://www.youtube.com/watch?v=VeXadyVSxj4
QUESTION:
IN YOUR SETUP DO YOU THINK IT WOULD BE POSSIBLE TO PUT YOUR SHORTED COIL ON A SWIVEL AND HAVE IT FACING AWAY FROM THE ROTOR AND THEN MOVE IT INTO POSITION ONCE THE ROTOR IS UP TO SPEED?
GOTOLUC AND I DID THIS AT OU (OTTAWA UNIVERSITY) BUT I DON'T HAVE ANY VIDEO ETC.
IF YOU WERE TO DO THIS I WOULD SUGGEST THAT YOU REPLACE YOUR ?ALUMINUM? BOLT MOUNT WHICH CREATES LOTS OF EDDY CURRENTS WITH STEEL WHICH WILL ATTRACT MORE ROTOR FLUX THROUGH YOUR CORE AND INCREASE YOUR COIL'S INDUCED VOLTAGE AND INCREASE THE EFFECTS. IF THAT COIL MOUNT IS INDEED ALUMINUM - IT OUGHT TO BE REPLACED ASAP.
CHEERS
T
CRANKYpants
HERE IS SOMETHING ELSE YOU CAN TRY IF YOU LIKE...?
1) MAKE A CONVENTIONAL COIL AND PLACE IT ON THE OTHER SIDE OF THE ROTOR TO
2)SHOW "CONVENTIONAL ON LOAD GENERATOR REACTION" AND
3) THEN FEED THE OUTPUT OF YOUR REGEN COIL INTO THE CONVENTIONAL GENERATOR COIL WHICH WOULD BE ACTING NOW AS A MOTOR COIL TO CREATE MORE ACCELERATION.
http://www.youtube.com/user/ThaneCHeins?feature=mhee#p/u/23/wOveW0Y4Mok
nilrehob's COMMENT IN HIS VIDEO, "THIS IS FUN" REALLY STARTS TO APPLY WHEN YOU SEE THAT YOU CAN SUPPLY POWER TO A LOAD AND BOOTSTRAP THE SYSTEM TO DRIVE ITSELF...  :o
CHEERS
T
hoptoad
Quote from: CRANKYpants on September 16, 2011, 07:33:23 AM
Oh that's right, C can't be attributed to your data because WITHOUT CORES ITS NOT A GENERATOR IT IS JUST A ROUND THING ROTATING IN THIN AIR...
AND BECAUSE ALL GENERATORS IN THIS CONTEXT HAVE:
1) WIRE AND WIRE RESISTANCE
2) BEARINGS AND BEARING RESISTANCE
3) CORES AND CORE RESISTANCE
BUT IF YOU ARE SINCERE AND YOU COMPARE APPLES TO APPLES I.E TWO IDENTICAL GENERATORS ON NO LOAD WITH:
4) THE SAME DRIVE SHAFT AT THE SAME RPM WITH THE SAME DRIVE SHAFT TORQUE SUPPLIED BY THE SAME PRIME MOVER BE IT AN ELECTRIC MOTOR, GAS OR DIESEL ENGINE, WIND, STEAM, WATER, DONKEY, GERBILS OR WHATEVER AS PDI HAS DONE. (SEE OTTAWA UNIVERSITY VIDEO BELOW)
5) THE CONVENTIONAL (REGENERATIVE BRAKING) GENERATOR WILL DECELERATE THE SYSTEM WHEN PLACED ON LOAD. AND THE GREATER THE LOAD THE FASTER THE RATE OF DECELERATION.
6) THE REGENERATIVE ACCELERATION GENERATOR WILL ACCELERATE THE SYSTEM WHEN PLACED ON LOAD AND THE GREATER THE LOAD THE FASTER THE RATE OF ACCELERATION.
7) THE REGENERATIVE ACCELERATION GENERATOR COIL WILL EVEN ACCELERATE WHEN THE LOAD IS ALMOST 7 TIMES GREATER THAN THE CONVENTIONAL LOAD AND
8) THE REGENERATIVE ACCELERATION GENERATOR WILL ALSO ACCELERATE THROUGH THE DECELERATION CAUSED BY THE CONVENTIONAL COIL AS SHOWN HERE WITH A PERFORMANCE ADVANTAGE THAT EXCEEDS 500%: http://www.youtube.com/watch?v=L3JVjbXOssQ
CHEERS
T
Thane C. Heins
President
Potential +/- Difference Inc. R & D
"The Transition of Power"
thaneh@potentialdifference.ca
Linkedin http://linkd.in/iIZyXF
YouTube http://bit.ly/gCRePU
"How do we make the world work for 100% of humanity in the shortest possible time
-through spontaneous cooperation without ecological damage or disadvantage to anyone"
~ Dr. R. Buckminster Fuller
When you demonstrate your generator running itself with no external power supply and motor driver, I'll be happy to applaud your ingenuity. In the meantime your comic relief, aka, yadda yadda, is worthy of a clap or two.
Overunityguide
Quote from: CRANKYpants on September 16, 2011, 07:54:30 AM
CHEERS
T
Dear Thane,
Actually the word which I was looking for was sceptics instead of critics...
But as you mentioned, cynics is maybe even beter...
But to answer your question, yes I am using a simple steel bolt as a core for now and indeed, the Generator Coil Casing is made out of aluminum...
I agree that this can be done much better, but my problem is that I don't have a machine shop myself, so unfortunately I have to stick with home improvement mechanics for now. And about the Swiveling mechanism, I have tried to run the motor without the generator coil, and it will give me a slightly lower input wattage. But this can be expected due to the eddy currents, and al other disadvantages of my simple setup...
CRANKYpants
Quote from: Overunityguide on September 16, 2011, 09:02:27 AM
But to answer your question, yes I am using a simple steel bolt as a core for now and indeed, the Generator Coil Casing is made out of aluminum... Overunityguide
SORRY I DIDN'T MEAN THE ROTOR - WHICH CAN BE ANYTHING INCLUDING LEXAN BUT NOT PLEXIGLASS AS GOTOLUC FOUND OUT WHEN HE BLEW UP HIS BROTHERS GARAGE!  :P
I MEANT THAT CORE/BOLT MOUNT WHICH IS SECURED TO THE WOOD - IS THAT ALUMINUM?
IF SO IT IS CREATING LENZ DRAG ON NO LOAD JUST BY SITTING THERE.
IF IT WERE "SOFT" STEEEL IT WOULD ATTRACT ROTOR FLUX AND PERFORM SLIGHTLY BETTER. THAT IS ALL I MEANT.
CHEERS
T
