Overunityguide
Hello You All,
Finally I have hooked up a Second Hand MOT (Microwave Oven Transformer)
Directly to my frequency drive controller. To be more precise, it is connected to the frequency drive controller by a 2.2 Ohms resistor, so that I can show the primary amperage going to my primary. And that I am able to show the phase angle between the voltage and the amperage on the primary side of my MOT.
I found that the results obtained are exactly the same as in my previous experiment about the home made transformer with a very high impedance secondary coil.
So this time I only have used normal Off-The-Shelf components. So please see my New Video about the Delayed Lenz effect on:
http://www.youtube.com/watch?v=-j3-x3JJDA4
It looks like my LED Light Bulb (load) on the secondary is running purely on reactive power by now!
With Kind Regards, Overunityguide
plengo
Magluvin
Quote from: Overunityguide on October 02, 2011, 02:40:25 PM
Hello You All,
Hmm,  if we had another secondary in there, on the other side of the primary, the input should go down even more, but will the combined outputs be more than 1.  ;]
Thanks for doing these tests.  Im sure everyone agrees this is good stuff.
Mags
CRANKYpants
Quote from: Magluvin on October 02, 2011, 04:40:57 PM
... but will the combined outputs be more than 1.  ;]
Mags
HELLO MAGS,
I WOULD NOT BE SURPRISED IF OUG IS ALREADY AT OU?  :o
MAYBE NOW WE CAN GET HIM A NEW JOB...
CHEERS
T
YouTube Message: Subject Efficiency %
Hey Overunityguide,
Really nice job!
Can you measure the power going to your LEDS?
I am assuming the PF is 1 so just Current and Voltage.
Lets say the power is 1.5 Watts for example.
Now assuming your MOT is purely reactive the power dissipated as heat should be primary I^2 x Rdcprimary.
You may be at OU already!?
Now people will say your FDG is part of the circuit but in reality it is not because the FDG can actually be replaced by a conventional generator running at 950 Hz and when combined with your MOT the CONVENTIONAL generator will be isolated from the load so NO armature reaction will take place.
Cheers
Thane
Sent to: overunityguide
PS WITH THIS IN MIND CAN YOU...
CONNECT YOUR GENERATOR TO YOUR MOT AND SEE WHAT HAPPENS AT 200 HZ AND 950 HZ COMING FROM THE GENERATOR INSTEAD OF THE F.D.C. - JUST CURIOUS?
WITH THIS SETUP YOU CAN HONESTLY SAY THE INPUT TO THE TRANSFORMER IS MEASURED RIGHT BEFORE THE PRIMARY AND THE OUTPUT IS THE POWER THROUGH THE LOAD.
BTW VARY THE LOADS BECAUSE YOU OUGHT TO FIND AN IDEAL LOAD WHICH PROVIDES MAX OUTPUT?
ramset
Boss
The Perfect Venue!!
We strap your Crankybut to one of these and you soar into the reccord books?? [2 min 10 sec we can beat that......]
OU Link    http://www.overunity.com/index.php?topic=11446.msg301687#new
From
Nul Points
Maxwell's Daemon ...my drinking buddy
Manned electric helicopter
« on: October 02, 2011, 12:01:00 PM »QuoteOn August 12, electrical/aerospace engineer and helicopter pilot Pascal Chretien took to the air in the world's first untethered, fully electric manned helicopter flight in a prototype machine that he designed and built almost entirely by himself within a 12 month development period. In his 2 minute, 10 second test flight, Chretien beat aviation giant Sikorsky into the record books...
...Chretien was able to achieve an 87.5% energy efficiency between the battery terminals and the rotor shafts...
  link-->http://www.elektor.com/news/world-s-first-untethered-manned-electric.1959672.lynkx?utm_source=UK&utm_medium=email&utm_campaign=news
Vive la France!
...Thane Heins version anyone?
cordialement
np
Think of all the Guiness reccords you'll be breakin!!
VIVA LA EARTH !!!!
Chet
Thanks Grandma
