gotoluc
Quote from: Overunityguide on October 19, 2011, 06:45:02 AM
To continue with the above, I now am thinking also that the Lenz Delay has to do something with the "CORE HYSTERISIS DELAYED EFFECT" which you are describing above, rather then that it has to do something with input or output coils of the transformer... So for now I do think that building a proper core which can be saturated above a certain level can be the key to further enhance the Delayed Lenz Effect.
Hi Overunityguide,
I also believe the Delayed Lenz effect has to do with the core.
Thanks for sharing your new tests results
Furthermore, I do think that the following Tesla patent can be very helpful when trying to do further experimentation in this Delayed Lenz Effect field:
http://www.teslauniverse.com/nikola-tesla-patents-433,702-electrical-transformer
You may also want to look at this Tesla Patent which is 4 years later then the one above.
http://www.google.com/patents?id=uwhBAAAAEBAJ&pg=PA1&source=gbs_selected_pages&cad=1#v=onepage&q&f=false
Thanks for sharing
Luc
DeepCut
Agreed with Luc on core material.
I am running my device at ~400 Hz.
I have tried ferrite, with poor, if any, acceleration under load or even short-circuit.
Bright, mild steel was OK, the effect was there.
My best results so far are from the loose bolts contained in masonry anchor shields, i'm unsure of their material composition but i cut into one and it looks like steel but could be an alloy.
The seller of the bolts doesn't have a clue what they are made from and seems to think i'm rather odd in asking ;+}
I just tried a bifilar/series coil with two conductors of different size, hoping that the difference in potential between them may enhance the effect, but it degrades it, the effect is still there but suffers by 30% in rotor frequency and 12% in currrent draw.
Best to all,
DC.
DeepCut
My laminations arrived today.
The performance was not as good as my loose anchor bolts !
Results in spreadsheet here :
http://www.mediafire.com/?zh6s7dwt21wx53h
If you don't have excel installed then get the viewer here :
http://www.microsoft.com/download/en/details.aspx?id=10
Best to all,
DC.
CRANKYpants
Quote from: gotoluc on October 19, 2011, 10:08:25 AM
Hi Overunityguide,
Thanks for sharing
Luc
YOU ARE ALL ON CRACK...!
IT'S NOT DELAYED LENZ AT ALL IT'S DIVERTED LENZ 8) http://www.youtube.com/watch?v=lu0MDMDChSg  8)
JUST KIDDING A BIT OF BOTH IS REQUIRED ;)
CHEERS
T
ramset
Deep cut
RE: anchor bolts and support sleeves.
Grade 5 material unless its Xtra high strength application [85 ->100,000. psi material]
There should be an AISI spec or an ASTM spec on the product for reference.
Chet
Thanks Grandma
