DeepCut
Thanks HT. You have added to my meagre knowledge ;+}
DC.
hoptoad
Quote from: DeepCut on February 20, 2013, 05:04:57 PM
DC.
Glad to help
Cheers
Newton II
Quote from: kEhYo77 on February 20, 2013, 04:05:06 AM
Take a look at this video from MrAnguswangus
Magnetic flux can travel through only certain  distance of length through any magnetic material.   That is the reason why magnetic material like iron or steel is used as magnetic shielding materials since they absorb the flux and limit their distance of flow (length wise).   If you use a very lengthy core,  the magnetic flux of the rotory magnet will be absorbed at the beginning of the core itself and this flux will not reach the coil at all.     In that case  you have to use very strong magnets to pump the flux through out the core.   For that you have to use very huge magnets. ( in the above said video the experimenter has used set of huge magnets).   For rotating huge magnets  you have to supply more input power to the motor.   With all that even if the generator produces acceleration under load the power out put cannot be more than the power input.
In any of the generators showing AUL,  can out put of the generator be fed back to the motor making the unit  perpetual ?   If not what is the use of AUL?
Have a look at this wiki page :  http://en.wikipedia.org/wiki/Perepiteia
As per this wiki page critics say that acceleration under load may indicate only higher effeiency or it is attained at the expense of torque.  Which means when rotor accelerates it loses its torque and there will not be any considerable gain in output.
Is there any relationship between torque and speed characteristics of a motor?   Can somebody expalin things correctly?
vineet_kiran
Quote from: Newton II on February 22, 2013, 09:29:58 AM
There is definitely relationship between torque and speed of a motor.   Torque is inversely proportional to the speed of the motor shaft.
Here is the copy of  personal message which I had sent to  Deepcut  since I felt  that he is very much interested in this experiment.   I don't claim that what I  have written is 100% correct but still it can throw some light on the subject.
Quote :
I saw few videos showing 'acceleration  under load'  effect in which they are using one DC motor, one generator with
some  adjustments in coil or core.    This  generator  gains  speed  of about 200 to 300 RPM when connected to load.   I
don't  think  this is of  any practical  use because  the  out put of the generator will still be lesser than the input to the
motor.   If you feed the output of generator back to the motor,  the system will not become perpetual.
As for my knowledge goes there are two types of DC motors.   One is torque motor and the other is speed motor.
In a torque motor  the  stator magnets  will  be of lesser  strength  inorder  to limit the back emf in the rotor winding.
This motor develops high torque with less speed.
In a speed motor the stator  magnets will be very  strong  which produces high speed of the rotor with lesser torque.
Even a small force is enough to stop this rotor.
In most of the videos demonstrating accelerating effect,   I  have observed  that they  have used torque motors.  This
raises  (accelerates)  the speed of  rotor  under load to a  small  extent  about 200  to 300 RPM because torque motors
are not designed to run at higher speeds.
I conducted  this experiment using a  speed motor.    For this,  I  had to  remove  the  existing  weak  magnet from the
DC  motor  and replace   it  with strong,  thick  magnets  without enclosure.  Once you convert torque motor to speed
motor,  it cannot run under high torque.   So  it cannot withstand lenz's forces produced in the generator under load.
To compensate  this,  I  reduced  the  gap  between  the  cores  so  that  the  strength  of  the  output current from the
generator goes down thereby reducing the lenz's forces.
Then I  coupled  the speed motor with generator having minimum gap between successive cores.    I raised the speed
of  motor to a critical speed by using power from a DC source.   When I shorted the output terminals of the generator,
the generator  rotor  developed  tremendous  speed  with  huge noise causing vibration of the entire setup and to an
extent it vibrated the table also.      The  difference  beween  noload  speed  and speed under load was few thousand
RPMs.
If you use   a  larger diameter   rotor in generator,  it  developes  a very  strong  torque at center with very high speed.
This  entire  setup  of  motor  and  generator  can be  used as a  single  motor  unit and  torque output from this motor
unit has to be coupled with standard, conventional generator to get standard AC / DC power output.
Incase  if  you  don't get  sufficient  torque  output  in  one  unit,   you may have to use several such units with torque
from preivious  one  coupled  to  successive  one  with  slightly  widened  gap  between  the  cores  and  you  have to
feed the torque output from the last unit to a standard generator.
The final  usable   power  output  has  to  be  got  from a standard  generator only.    Any modification of the standard
generator  will  not  produce  the required   strong power output.     These  standard  generators  have  evolved  from
decades of research work and they donot have any drawbacks.
It is all not that easy as Mr.Thane Heins thinks.   I don't think that his bicycle will ever run!
I  had  posted  this  experiment  in OU.com  under  following link.   In  that I  have  not  mentioned  that  I  have  used
a speed motor.
http://www.overunity.com/10774/over-unity-by-reaction-helping-action/msg287484/#msg287484
Sorry for my clumsy english.   I hope you will understand what I have written.     Waiting for reply.
Vineet.K.
Unquote
DeepCut
I'll tell you what use i think AUL will be, when i get there (if i get there!).
Say our rotor does 2000 RPM for 10 watts of power when there is no AUL coil assembly present, just a rotor with no coils/cores.
Then we present our shorted coil assembly to the rotor, the rotor does 2,100 RPM and draws 9 watts.
That is what i am aiming for, a coil that accelerates the rotor beyond its no-coil speed.
The last coil i tried weighed 2 pounds, had an inductance of over 10 Henries and a resistance of a couple of hundred ohms, it's time constant was around 28ms.
When i presented this coil to the rotor the speed dropped by5 hertz and the input current rose by only 5mA.
My point is, each time i use a better coil (high inductance/low resistance) the results are getting better and better, i can only assume that a 3lb coil will extend the performance graph in the direction it's been going : up :)
Obviously there's lots i don't know, i'm not trained in nor do i have any expertise in things electric/electronic, so i can only go on what i see in my hands.
Also, the AUL effect doesn't break any laws of physics, if we believe Thane's model it uses the CEMF, so you are using the 'equal and opposite reaction', not negating it.
I am extending my DC motor-driven version to allow for longer coils (200mm) :
(http://i1235.photobucket.com/albums/ff437/deepcut71/Energy%20Experiments/side_zps3fe5faeb.png)
The thing is only half-built at the moment as i am awaiting more parts, the wooden base will be replaced by acrylic, the plastic coil-former barrel is on the right, it is 200mm long :
12 magnets and 6 coils :
(http://i1235.photobucket.com/albums/ff437/deepcut71/Energy%20Experiments/planview_zps45f39ebd.png)
Cheers,
DC.
