gyulasun
Quote from: synchro1 on March 02, 2013, 10:40:50 AM
... Dragone patented the Magnet pump Generator. Two disk magnets on each end of a core winding. The field oscillation inside the magnet core output coil accounts for a good share of the abundant amperage. All the time, the slowed pole shift from very powerful magnet core field interference, motors the prime mover like a pulse coil. The power agitated by the spinner hepls drive the rotor magnet with greater force. Three great advantages in one!
Hi synchro1,
I searched for Dragone Magnet pump Generator but I found only one patent (application) by Leon Dragone: Electro Entropic Generator, patent (application) number is GR871255. Is that what you meant?  If you did not mean that please refer to his patent you really meant.
(this is a link to the Greek patent (application): http://worldwide.espacenet.com/publicationDetails/originalDocument?CC=GR&NR=871255A1&KC=A1&FT=D&ND=3&date=19870814&DB=worldwide.espacenet.com&locale=en_EP )
I know there have been a Dragone paper on the net for many years but it not a patent (if you meant that).
Gyula
synchro1
This PDF of Leon's is somewhat turgid, but in the final diagram, one can see that the permanent magnet field is pushed over to one side at an angle of 45 Degrees by the coil charge sandwiched between the disk magnets. Note the size of the disk magnets and their polarity.
http://www.esmhome.org/library/leon-dragone/energetics-of-ferromagnetism-leon-dragone.pdf
The conclusion is that PM magnorestriction by coil field, generates power, because the PM has to do more work to realign itself, and eats ambient room heat to restructure on the quantum plane. Leon mentions the "barkhausen" interval too. I believe the same effect helps make the magnet core output coil O.U. My Dragone experiments demonstrated the PM field return generating power in the relaxation phase of the pulse coil.
There is "Magnorestriction" around the PM fields in the output coil, when the tardy pole shift finaly manifests itself. A current appears in the output coil from relaxation phase. This event follows and reinforces the retro-pulse.
DeepCut
Quote from: MileHigh on March 06, 2013, 08:43:39 AM
DeepCut:
You are back to sulking in a corner.  Another gratuitous ad hominem attack from you for no reason.  Indeed, stop wasting your time and get yourself together.  I don't need your nonsensical sourpuss bashing.  If I thought that Synchro1 had something unique and of merit I would say that but all that I see is an ordinary pulse motor.  Life is so tough sometimes.
Anyway, I am going to leave this thread because there is nothing here.
Always with the 'sulking in a corner', what corner of your consciousness is that coming from, i wonder ?
You know why you were kicked off OUR and you know your reputation with most of us so you know exactly where i'm coming from.
You have a reputation for being so repeatedly negative that you have ruined threads and scared off more sensitive souls than i.
Anyway i'm glad you've left the thread and i'm even more glad you've learnt a little Latin while you were here.
I hope you find some positivity somewhere MH.
DC.
DeepCut
Quote from: synchro1 on March 06, 2013, 01:28:02 PM
So it IS more than simply retarding the rise-time.
That explains why the effect is stronger and stronger at higher and higher frequencies and there is no wrap-around into deceleration-under-load bands.
It may also explain why it is possible to short or load the coil, get your acceleration and your current input drop, then UN-short/load the coil and the decreased curent draw and increase acceleration remain in effect.
More and more interesting, thanks synchro.
All the best,
DC.
synchro1
Leon Dragone outlines the very simple nature of his electrical 'heat pump'
effect. His system consists of nothing more than a coil, a magnet, a power
supply, and a switch. He places a permanent magnet within a copper coil and
energizes the coil so that the external field of the magnet is
removed/compressed from the space around the magnet, without changing the
polarity domains within the magnet itself. He then employs an arc switch
(simple contacts) to quickly disconnect the power supply from the coil, and
leaves the coil open circuit. Suddenly the field of the permanent magnet is
free to expand back out to its 'normal' geometry around the magnet. But the
process of expanding this field requires work. The coil is open circuit, so
the energy can not be drawn from current in the coil. The field must
reinstate itself. Energy is drawn from the vibrating molecular domains
within the magnet, causing a measured drop in temperature of the magnet.
Essentially, ambient heat is transformed into work to reinstate the field.
Any inductive load applied while the field is expanding/relaxing is driven
by extraction of ambient heat energy from the surrounding enviroment.
Dragone claims to have measured experimental system energy gains on the
order of 20:1, using this approach.
