DeepCut
Sounds good.
I should be able to give that a go tomorrow, cheers synchro :)
atb,
DC.
gotoluc
Quote from: synchro1 on March 18, 2013, 07:21:05 PM
The strong PM core field retards the pole shift in the output coil as opposite approaching magnet poles influence it. This is  like the addition of pancake coils one on the other. This generates the propulsion.
Hi synchro1, lets see if I understand you correctly.
Generator coil:
Wind a cylinder (solenoid style) bi-filar series connected coil with a center opening large enough to accommodate a free spinning cylinder diametric polarized magnet in its inside center will result in a Lenz free generator at any rpm?
Luc
crazycut06
Quote from: gotoluc on March 18, 2013, 04:11:49 PM
Hi everyone,
a warning to everyone. I contacted skycollection around 2 months ago when he started experimenting with bi-filar pancake coils as generator coils. At that time he did not have the delayed Lenz effect.  Some of you may know that I worked with Thane Heins.
I thought skycollection high rpm magnetic bearing motor would be able to demonstrate a good effect so I freely shared how to connect the many layers of bi-filar pancake coils in a way to raise the self capacitance. We exchanged many emails.
To make a long story short, about a week after our exchange he got the effect, so I made some more suggestions and he replied this was all his own ideas. That's when I realized this guy is in it for himself. Notice he does not show how to builds anything.
Just thought I would share that
Luc
That's sad  :(
crazycut06
Quote from: gotoluc on March 18, 2013, 07:51:22 PM
Generator coil:
Luc
That's a cool idea, with the main rotor magnet spinning, creating induction to the coil and inside it there's a  free spinning magnet also, causing induction to the coil hmmm... I wonder What would be the effect?
Cc
ALVARO_CS
Hello all
I´ve been watching the skycollection videos from the beginning, and although I admire his craftmanship, I cannot say the same of his speech.
Always showing things, and always hiding the main details or the circuit schematics, . . . . fustrating
here is the translation of this last video. . . . (take your own conclusions)
-well
-in this occasion we`re gonna make a small sketch of what is the magnetic induction
-well so. . . the magnetic induction is the difference of potential or the voltage produced through a conductor when it is exposed to a variable field
-well here is the case
-here we have an inductor, but this inductor is a special case because it does not have alternate currents that could disrupt the rotor rotation
-here has been removed (eliminated) mostly the induction generated by the magnets, or the Lenz effect was here eliminated.
-and we´re gonna prove it with this magnets rotor, and we have here four inductors some coils that are driving the motor and the others are inductors
-well we´re gonna test it
- well here the current starts to be generated in the inductors
-practically all of them were turned on
-and as you can see there is no resistance to impede the rotor to turn
-and this is what is consumed in this motor
-we´re making subsequently a calculation about the production in each one of the inductors
-and here the Lenz effect is been deleted
-we have no resistance, just the air
-and this leads me to produce in the future this interesting coil which has not the Lenz effect
-well thank you very much for your attention
regards
Alvaro
