FIRST FREE ENERGY DEVICE REACHES MARKET IN OCTOBER -- The Game Changer is Here
Started by chessnyt, September 16, 2011, 06:57:24 PM
The new poll  starting 2-4-2012:  LENR technology
a) will soon lead to the end of the fossil fuel era and become the new standard.
b) will compete with fossil fuels for decades to come eventually replacing them.
c) will not only phase out fossil fuels but will also lead to the trials of the current corrupt powers in charge.
d) will lead to all of the above.
happyfunball
So... as of today, there is still no confirmed radiation within the chamber and this thing is still being called LENR? Is that right?
chessnyt
Quote from: happyfunball on October 09, 2011, 11:19:16 AM
@Happyfunball:
No, there were no measurements taken of radiation levels from within the reactor.  There were also no measurements taken for tritium levels or helium as well.
There were two main issues Rossi was trying to address in his most recent testing.  One was that the device was able to produce energy well after ALL EXTERNAL POWER was removed from the unit.  The second issue (that was argued about extensively by top scientists in the test prior to the most recent one) was the quality of steam issue.  This was addressed by incorporating a heat exchanger which was NOT 100% efficient thus leading to heat measurements much lower than they should have been.  But even despite the deck stacked against it from the start, the device was able to easily demonstrate over unity performance which qualified independent scientists concluded could only have come from a nuclear reaction (ruling out other types of reactions such as chemical ones, etc.).
As far as radiation goes, even Paul Pantone’s GEET reactor was proven by a third party to emit enormous amounts of radiation (because he used no lead shielding at all), however, later it was determined that the radiation was not Gamma or any other harmful type of radiation being emitted from his reactor.
So radiation can be produced by lower temperature (lower than hot fission temperatures) reactions and comes as not such a surprise when you consider other low energy reactions can produce radiation.
Chess
happyfunball
Quote from: chessnyt on October 09, 2011, 12:20:06 PM
@Happyfunball:
Chess
I find this user comment from Peswiki quite interesting. I suspect it is at the core of this scam:
"After consulting with various people and reading data reports it is unfortunate that the following has to be concluded.
1. Rossi specifically disallowed anyone to know the location of the output thermocouple. This is the same mistake Levi made in February. The thermocouple is not measuring the water flow temperature. It is measuring the temperature of the metal block in contact with the heater.
2. The rise of the temperature after turning off the power is clear evidence that the thermocouple is in the wrong position for taking data. It will never pass real scrutiny.
3. http://www.mtaonline.net/~hheffner/Rossi6Oct2011Review.pdf"
chessnyt
Quote from: happyfunball on October 09, 2011, 04:39:07 PM
@Happyfunball:
I’ll let Rossi address your question.  Pay close attention to the statements in bold print.  The following is a direct quote from Rossi himself earlier today:
Andrea Rossi
October 9th, 2011 at 2:26 AM
David Roberson,
Good question, and opportune indeed.
“NOT ONLY I CONFIRM THAT I VERIFIED THAT THE WATER TEMPERATURE IN THE EXHAUST STREAM UNDER OPERATING CONDITIONS HAS BEEN MEASURED AND MATCHES THE READING SEEN ON THE TEST THERMOCOUPLES, BUT EVERYBODY CAN EASILY CHECK IT EVERYWHERE WITH FEW DOLLARS , WITHOUT ANY RISK: IN THE REPORT MADE BY NYTEKNIK THERE ARE THE PHOTOS OF THE CONNECTORS WHERE WE PUT THE THERMOCOUPLE; JUST GO IN ANY SHOP FOR PLUMBERS AND BUY THE SAME ARTICLE ( IT COSTS LESS THAN 10 $). ONCE YOU GOT IT, GO IN YOUR BATHROOM , CONNECT THE TOY WITH RUBBER HOSES ( ANY RUBBER HOSE) AND MAKE HOT WATER FLOW IN ONE ROW, AND COLD WATER FLOW IN THE OTHER, PUT AT THE OPPOSITE SIDE. ONCE YOU DID THIS, TAKE A THERMOMETER AND MEASURE THE TEMPERATURE IN THE EXACT PLACE WHERE WE PUT THE THERMOCOUPLE, THEN MEASURE THE TEMPERATURE AT A DISTANCE OF A COUPLE OF INCHES AFTER SUCH POSITION, ALONG THE WATER FLOW. IF YOU FIND ANY DIFFERENCE, LET ME KNOW: I NEVER DID . OF COURSE, THE MORE DISTANT YOU GO, THE MORE THE TEMPERATURE DECREASES, SO IT IS LOGIC THAT TO MEASURE THE POWER WE HAVE TO STAY IN PROXIMITY OF THE WATER FLOW EXIT.
I WANT TO ADD THAT, TO ANSWER TO THE FRAUDOLENT STATEMENTS MADE FROM THE SNAKES PAID BY THE USUAL WELL KNOWN TO DISCREDIT AND BLACKMAIL US (YES, I REPEAT: BLACKMAIL US):
1- THE CALCULATION OF ENERGY MADE BY THE SNAKES ARE EMBARASSINGLY WRONG, JUST ANALYZE THE RATIO BETWEEN THE ENERGY INPUT AND THE ENERGY OUTPUT IN THE PUBLISHED REPORTS. BY HTE WAY: TO BE HONEST, THE REAL EFFICIENCY SHOULD BE CALCULATED AFTER 3 P.M., WHEN THE E-CAT WAS STABILIZED, BUT, NEVERTHELESS, ALSO BEFORE IT THE AMOUNT OF ENERGY PRODUCED HAS BEEN MORE THAN THE CONSUMED…READ CAREFULLY THE PERIODS OF RESISTANCE SWITCH ON/SWITCH OFF DURING THE FIRST HOURS, BEFORE 3 P.M.: THE RESISTANCE HAS A POWER OF 2.5 Kw AT FULL LOAD, SO IF YOU MAKE IT GO 10 MINUTES YES AND 10 MINUTES NO YOU CONSUME 1.25 kWh/h, WHILE THE PRODUCTION WAS WELL ABOVE…AND WE WERE IN THE START UP UNSTABILIZED PHASE !!! AFTER THAT, WE WORKED WITH THE RESISTANCE FOR FEW MINUTES AND 3 AND A HALF HOURS WITHOUT RESISISTANCE TURNED ON. EVERYBODY CAN READ IT VERY CLEARLY IN THE NYTEKNIK REPORT.
2- IT HAS BEEN FRAUDOLENTLY WRITTEN IN THE BLOGS OF THE SNAKES THAT THE DEVICE HAS BEEN NOT WEIGHTED: FALSE, THE E-CAT AND ALSO THE CALORIMETRIC ASSEMBLY HAVE BEEN WEIGHTED BEFORE AND AFTER THE TEST, AND THIS IS CLEARLY WRITTEN IN THE SAME REPORT OF NYTEKNIK: CLEARLY, THE SNAKES THINK THAT THEIR READERS ARE SO STUPID NOT TO BE ABLE TO READ THE REPORT, BUT, UNFORTUNATELY FOR THEM, IT IS NOT SO. I WANT TO UNDERLINE THAT NOT ONLY ALL HAS BEEN WEIGHTED, BUT ALSO THAT AT THE END OF THE TEST I HAVE DISASSEMBLED IN FRONT OF ALL THE ATTENDANTS ALL THE PIECES, AND TAKEN OFF THE INSUILATION TO MAKE WELL CLEAR THAT EVERY COMPONENT WAS CLEAN, THAT THERE WERE NOT BATTERIES, OR ANY KIND OF POTENTIAL ENERGY SUPPLY INSIDE THE E-CAT AND INSIDE ALL THE OTHER COMPONENTS; FOR THIS REASON WE HAD TO STOP THE E-CAT, (WE FINISHED AROUND MIDNIGHT) OTHERWISE IT WOULD HAVE CONTINUED TO WORK ALONG THE SAME EFFICIENCY REACHED AFTER THE STABILIZATION. ALL THESE OPERATIONS HAVE BEEN MADE IN FRONT OF HIGH LEVEL SCIENTISTS ARRIVED FROM: UNIVERSITY OF UPPSALA, UNIVERSITY OF PARIS, UNIVERSITY OF BOLOGNA, US NAVY, RESEARCH CENTER OG CHINA, HIGH LEVEL INDUSTRIAL CONCERNS, UNIVERSITY OF ATHENS, AND I AM SURE I AM FORGETTING SOME: I ALLOWED ALL THIS PEOPLE TO BE PRESENT AN LOOK AT ALL THE OPERATIONS MADE DURING THE TEST: WEIGHTING, DISASSEMBLING, OPERATION, EVERYTHING! BESIDES: WEIGHTING ETC HAS NOT BEEN MADE BY US, TEMPERATURES HAVE NOT BEEN CONTROLLED BY US, BUT BY THE ATTENDANTS.
A SNAKE HAS WRITTEN THAT INSEDE THE E-CAT THERE WAS DIESEL OIL TO BE BURNT………JUST LOOK AT THE WEIGHTS: AT THE END OF THE OPERATION THE E-CAT WEIGHTED SOME GRAM MORE THAT BEFORE THE OPERATION….
Thank you for your question, very useful.
Warm Regards,
A.R.”
SOURCE:
http://www.facebook.com/note.php?note_id=300479616635504
happyfunball
Quote from: chessnyt on October 09, 2011, 05:12:44 PM
@Happyfunball:
Andrea Rossi
David Roberson,
Warm Regards,
A.R.”
SOURCE:
Ok. We'll eventually see who's telling the truth I guess.
