Ibpointless2 Crystal Cells
triffid
Hi everyone,I have been trying to help Merfedit with an experiment and found a way to make carbon nanotubes at home by accident!I used a long nose bic lighter for barbecue,butane powered.I bought this one on sale at the store for $2.50.I tried to ignite a piece of borax treated magnesium but the darn(thats D A R N) thing would not light!The yellow flame from the butane lighter was putting soot on the strip of magnesium.So I thought thats the carbon nanotubes there!So I stopped trying to light the magnesium and took voltages.I got .60 volts most of the time and got an amp reading(the highest) of .003 mAs.So my experiment went off in a different direction.This is a success all by itself.I used a piece of my borax treated magnesium,could not light it after two minutes but it got hot and covered with black carbon soot from a yellow flame butane powered bic lighter.They have found nanotubes and buckyballs in soot.I will save this piece of soot covered magnesium and take readings in the days to come.triffid
I get about .002 milliwatts from this one piece of borax treated magnesium strip.
Where I held the strip with pliers theres a clear area.So I put the voltmeter there and on the soot.
Murfedit
Success!! I love that word :-D
This whole experiment makes me want a scanning electron microscope badly
Grats Ib and thank you again
triffid
http://en.wikipedia.org/wiki/Carbon_nanotube
Nanotubes were observed in 1991 in the carbon soot of graphite electrodes during an arc discharge, by using a current of 100 amps, that was intended to produce fullerenes.[65] However the first macroscopic production of carbon nanotubes was made in 1992 by two researchers at NEC's Fundamental Research Laboratory.[66] The method used was the same as in 1991. During this process, the carbon contained in the negative electrode sublimates because of the high-discharge temperatures. Because nanotubes were initially discovered using this technique, it has been the most widely used method of nanotube synthesis.
The yield for this method is up to 30% by weight and it produces both single- and multi-walled nanotubes with lengths of up to 50 micrometers with few structural defects.[31]
triffid
http://en.wikipedia.org/wiki/Soot Soot is a powdered form of
http://en.wikipedia.org/wiki/Amorphous_carbon
Coal and soot are both informally called amorphous carbon. However, both are products of pyrolysis, which does not produce true amorphous carbon under normal conditions. The coal industry divides coal up into various grades depending on the amount of carbon present in the sample compared to the amount of impurities. The highest grade, anthracite, is about 90 percent carbon and 10% other elements. Bituminous coal is about 75-90 percent carbon, and lignite is the name for coal that is around 55 percent carbon.
triffid
http://en.wikipedia.org/wiki/Carbon_nanofoam   The nanofoam contains numerous unpaired electrons, which Rode and colleagues propose is due to carbon atoms with only three bonds that are found at topological and bonding defects. This gives rise to what is perhaps carbon nanofoam's most unusual feature: it is attracted to magnets, and below âˆ'183 °C can itself be made magnetic.
