Video On line, Proof Of Overunity With Permanent Magnets, LaFonte Research
Started by gammarayburst, November 29, 2011, 10:26:24 PM
norman6538
considering this annimation http://home.planet.nl/~sintt000/ButchVideo.wmv
and this basic principle
Two like polarity facing magnets will repel and push away
only after they have been squeezed together similar to a coil spring.
it boils down to this -
two adjacent magnets with the same polarity up will repel each other
but if placed on a metal plate they will NOT repel.
then easily moving/sliding one magnet across a metal gap to another plate switches to a repel of the two plates -  and without having to squeeze first.  maybe  ???
But then when returning the moved magnet to the original
place will there have to be a squeeze?
I have measured this and there is some visible evidence
that the repel of two magnets is greater than then repel
with those magnets on metal which effectively diffuses
that repel force.
Norman
Low-Q
Quote from: norman6538 on January 31, 2014, 08:25:22 PM
that repel force.
Norman
I think this must be tested in practice to understand it. It is hard to imagine all forces in a magnetic design like this or other designes just by looking on them. The animation shows how it is suppose to work, and that confuse the mind when trying to analyze why it does not work. Because, devices that is designed as a closed loop will never produce excess energy. The math adds up without exceptions - resulting in zero output.
Vidar
norman6538
So Low-q how do you propose getting out of the closed loop?
My brain won't stretch that far.
Norman
Low-Q
Quote from: norman6538 on February 01, 2014, 12:44:23 PM
Norman
The only way to get out of the closed loop is to allow external energy to run it. But then you could instead used the external energy source to run something useful directly instead of going through this magnet/iron design first :-)
Vidar
Newton II
Interesting animation.  But the rolling magnets should only collide with fixed magnet and roll back even if they don't experience repulsion from fixed magnet.  Why do you expect it to climb up the fixed magnet lifting its own weight against repulsion?
I think if you make few design changes IT WILL WORK!!
