Video On line, Proof Of Overunity With Permanent Magnets, LaFonte Research
Started by gammarayburst, November 29, 2011, 10:26:24 PM
Low-Q
Quote from: Newton II on February 01, 2014, 09:32:17 PM
Interesting animation.  But the rolling magnets should only collide with fixed magnet and roll back even if they don't experience repulsion from fixed magnet.  Why do you expect it to climb up the fixed magnet lifting its own weight against repulsion?
I think if you make few design changes IT WILL WORK!!
The magnets are not fully shielded, so therfor the moving magnet will not approach the stationary one without effort. There will be repulsion between the magnets - relatively strong repulsion. To reduce this repulsion, the magnets must be shielded better, but then the iron pieces will not repel eachother that well anymore.
This design does not work. If one add force in one place, another place will be weak. This is a closed loop and must give and take equally. The sum is therfor zero. A closed loop cannot produce energy. It will procude exact the same amount of energy as when no parts are moving at all.
Vidar
vineet_kiran
Low-Q
Quote from: vineet_kiran on February 02, 2014, 04:24:05 AM
I agree.  It can be made to work!
Don't trust your imagination when it comes to over unity machines. Your own bubble of imaginary reality doesn't change the real world ;-)
Sorry. It will not work.
Vidar
norman6538
Newton II said " I think if you make few design changes IT WILL WORK!!"
Therefore what design changes do you suggest?
I'm all ears.
Norman
Newton II
Quote from: norman6538 on February 02, 2014, 06:59:19 AM
I'm all ears.
Norman
Making the magnets to climb up the repelling fixed magnets as shown in your simulation would be a difficult task.   You may have to suspend these magnets by a solid bar as shown by Gammarayburst in his first video and  provide a iron channel below as shown in your simulation to cover repulsion upto some distance before the fixed magnets.  Magnets swing and pass through the sticky point by momentum at the edge of the channel and get repelled by the fixed magnets.  Which will (may) push the swinging magnets back to its original position repeating the cycle.   The iron channel provided should cover the  faces of swinging magnets completely,  totally neutralizing the flux.
