Gravity "wheel" concept...
Started by iacob alex, June 25, 2006, 05:33:48 AM
iacob alex
   .....has,as a main "actor" (symbol),a full up-down pendular fall in gravity.
        The down-stroke of a pendulum in gravity,has some similarities with the incoming tidal waves...in a certain manner,can be considered a real gravity wave.
        The term "wheel" is a vague,not clearly word :for a fish (body-tail),the tail is the prime mover.
         For a possible gravity power collector,as a likeness of a sea-shore wave power station,we are concerned about the big waves,not ripples( see "Wheel vs. lever" topic)
                  All the best! / Alex
onthecuttingedge2005
Quote from: iacob alex on October 22, 2009, 02:37:02 PM
technically Gravity isn't a wave, it is a lensing, the interaction of this lensing moving across a surface causes longitudinal waves with large moving bodies.
the term gravity wave is sort of a misnomer.
Gravity does not have a dipole field like EMF and doesn't form sine waves like EMF, instead any sine wave activity is a direct result of longitudinal waves from the monopole tensor(Gravity) field moving across and interacting body.
these monopole tensor fields or Gravity can have variable lensing densities that causes Gravity to be stronger in one area rather than another due to the density of the interacting mass densities spread out across a planetary body.
did you know that Mt. Everest is so big that it actually has its own Gravitational field, it can mis-align a plumbob by up to 3mm off dead center if placed at the base of the mountain.
iacob alex
      Hi Onthecuttingedge!
  Mark Twain said that a text is a frame between two mental words:what the sender  sees vs. what the people can or like to see.
  This is the case here.....we can't detect the gravitational waves,but we can "pack" the gravity fall,as a powerful wave of energy,as on the sea-shore in a wave power plant.
  Then we can temporarely collect this power
in a flywheel,and play it.
  All that we need,to obtain a self energetic system,is to play in such a manner this power,so to get a self pulsatory vortex-contravortex,with capabilities for a serviceable output.
  Anyway,some designs are more clearly and fully expressive on my web site...than a plenty of words.
Hi Alex.
Do you have a link to the work on your website?
Thanks.
Jerry
iacob alex
   Hi Jerry!
  Try a search with the key -word "Stellarotor" on net,or simply :     www.geocities.com/iacob_alex
