Juan Carlos Aviles Moran and George green :: The easiest True Magnetic Motors
Started by theshiningeagle, April 05, 2012, 05:09:33 PM
magnetologia
http://www.uspto.gov/cgi-bin/exitconf/internet_exitconf.pl?target=www.inventnow.org
You are exiting the United States Patent and Trademark Office Web Server
We have provided a link to this site because it has information that may be of interest to our users. The United States Patent and Trademark Office does not necessarily endorse the views expressed or the facts presented on this site. Further, the United States Patent and Trademark Office does not endorse any commercial products that may be advertised or available on this site.
We hope your visit was informative and enjoyable.
Click on >>>  http://www.inventnow.org  <<< to proceed
Thank you for visiting.
InventNow.org - Patent Certificatewww.inventnow.org/patent_certificate/?ph... JUAN CARLOS AVILES MORAN. ARTIFICIAL MAGNETIC MONOPOLES. August 26, 2010.http://www.inventnow.org/patent_certificate/?ph=f72b278edda3d16a74d3af9b03eb2449
------------------------------------------------------------------------------------------------------------------InventNow.org - Patent  Certificatewww.inventnow.org/patent_certificate/?ph=... - Traducir esta páginaJUAN CARLOS AVILES MORAN. MAGNETIC REPELLENCY UNIT. October 27, 2009.http://www.inventnow.org/patent_certificate/?ph=150ba93b9322a3f3d154723e954c9dd0
magnetologia
In 2009 , The new investigation of Juan Carlos Aviles Moran of the perpetual moving body using magnetic repellency Invented: October 27, 2009  (To give form to the magnetic field using metamateriales to create a continuous impelling magnetic field; to maximize magnetic repellency and to diminish resistance using Metamateriales, are created the artificial magnetic monopole what gives like result continuous displacement; Positive feedback or positive refeeding of the displacement by magnetic repellency) the magnetic fields that interact with other magnetic fields of equal polarity do not undergo variants in their temperature that is to say, maintain stable or constant a temperature. we remember does not exist friction in this rotating system therefore there is lost of heat nor no increase of heat The kinetic one can be understood better with examples than they demonstrate how this one becomes of other types of energy and to other types of energy. For example a cyclist wants to use the chemical energy that she provided his food to him to accelerate his bicycle at a chosen speed. Its rapidity can stay without much work, by the air resistance and friction. The energy turned into an energy of movement, well-known as kinetic energy but the process is not completely efficient and the cyclist also produces heat. Taking as an example we are going to compare the obtained kinetic energy of the cyclist when pedalear; comparing it with the push generated by the shock of magnetic fields of equal polarity; (the magnetic fields that interact with other magnetic fields of equal polarity do not undergo variants in their temperature that is to say, maintain stable or constant a temperature. we remember does not exist friction in this rotating system therefore there is lost of heat nor no increase of heat). Being therefore the kinetic energy obtained by the push of the magnetic repellency it is an efficient process. Unit of Magnetic repellency (U.R.M Unit of magnetic repellency is the insertion, compression and extension " Continuous" of magnetic fields of equal polarity; result of " Confront" artificial magnetic poles; Artificial magnetic Monopolo is a magnet or magneto to which part of its magnetic field within an alloy has been contained him or alternating layers of Metamateriales leaving it of artificial way with a single active magnetic polarity).
http://peswiki.com/index.php/Perpetual_motion
Artificial magnetic Monopole "or" Artificial Magnetic Monopoles is a magnet or magneto to which part of its magnetic field within an alloy has been contained him or alternating layers of Metamateriales leaving it of artificial way with a single active magnetic polarity invented by Juan Carlos Avilés Moran.
Metamaterials not allow the connection of lines of force of different polarity (magnetic attraction) Author: Juan Carlos Aviles Moran .
insulating magnetic shield is a redirector or the flow of magnetic fields, I disabled the polarity of your selection, making the artificial pole magnet. without shielding the magnets repel each turn attract  and thus balancing  the magnetic fields.
Juan Carlos Aviles Moran discovers the physical phenomenon called cascade magnetic repellency this cascade is a unidirectional magnetic repellency force indicted in the ring of magnetic repellency unit of magnetic repellency or mill, the cascade of magnetic repellency is but one path repellency continues along which the magnets of the rotor shaft of the MRU to be repelled by the ring magnets, magnetic repellency cascading series such as shock energy of water in a common mill.
the shield should be proportional to the magnetic field even when confronted remember attraction magnets of the same polarity and repel at the same time trying to attract the attraction is to be removed.
the shield should have a higher density to block the magnetic field of attraction of the magnets so it creates a cascade of magnetic repellency is a path as a highway for the axis magnets to be repelled any bad position in the ring equals a road bump in which no shaft magnets rotate.
http://peswiki.com/index.php/Magnetic_Repellency_Unit
Magnetic Repellency Unit (M.R.U) created by Juan Carlos Aviles Moran.
definition: Unit of magnetic repellency  "or" Magnetic repellency unit is the insertion, compression and rebound "Continue" in the same polarity magnetic fields, the result of "confrontations" artificial magnetic monopoles. Author: Juan Carlos Aviles Moran.
magnetologia
INFORMATION Energy.gov | Department of Energy United States knows the magnetic repellency unit project.
Date: Thu, 15 Jul 2010 13:42:54 -0400
To: repelencia@hotmail.com
Subject: Abstract Response
Dear Mr. Moran, Your abstract entitled “Magnetic Repellency Unit (M.R.U)” has been reviewed by technical personnel at the Department of Energy (DOE), National Energy Technology Laboratory (NETL) After initial review, it was determined that there was not enough technical information to forward on for programmatic interest.  We recommend completing an energy balance on the system.  Information on energy balance can be found at http://en.wikipedia.org/wiki/Energy_balance.  Please resubmit your abstract including this new information for review. If you would like to identify future opportunity announcements and register to obtain grant e-mail notifications of those that may interest you, go to www.grants.gov.  After clicking on ‘Find Grant Opportunity,’ you may apply for notifications under ‘e-mail subscriptions’; then click on ‘Notices Based on Advanced Criteria’ to subscribe for specific areas that interest you.  You will have to insert a Catalog of Federal Domestic Assistance (CFDA) number on this page.  The General Services Administration provides access to the CFDA, which is a government-wide compendium of Federal programs, projects, services, and activities that provide assistance or benefits to the American public.  The website contains financial and non-financial Federal assistance programs.   The CFDA website is located at www.cfda.gov; under “Search” (right side of screen), click “Find Programs by Agency”.  The Dept. of Energy CFDA numbers can be located at: https://cfda.symplicity.com/?s=agency&mode=form&tab=program&id=f9b483c381bd2a656b43cec368f9438f. If you have further questions, please contact me. John N. Augustine DOE Unsolicited Proposal Manager john.augustine@netl.doe.gov    Angela Lanauze, PRC DOE Unsolicited Proposals angela.lanauze@netl.doe.gov
  Date: Fri, 16 Jul 2010 10:58:58 -0400
Subject: Abstract Acknowledgment
Mr. Moran    Your abstract (including the new information) has been received by the Department of Energy Unsolicited Proposal Office and forwarded on for review to determine programmatic interest.  Please allow 4-6 weeks for your abstract to be reviewed. Once the review of your information has been completed, you will be notified of the results.    In the interim, you may consider accessing the following websites (www.energy.gov/recovery/funding.htm and www.netl.doe.gov/business/solicitations/index.html) which list open Financial Opportunity Announcements (FOA's) and consider submitting a proposal should your technology apply.  If your technology fits under the scope of an FOA and you do not submit a proposal, rules do not allow us to accept an unsolicited proposal (USP) that would have been in response to a competitive announcement.    Thank you. Angela Lanauze, PRC DOE Unsolicited Proposals angela.lanauze@netl.doe.gov
Date: Tue, 13 Jul 2010 08:08:39 -0400
Subject: Abstract/Unsolicited Proposal Information
Mr. Moran,   Per the email received on 7/11/10...    WITH THE INCREASED ACTIVITY OF FINANCIAL OPPORTUNITY ANNOUNCEMENTS (FOA'S) PUBLISHED AT THIS TIME DUE TO THE STIMULUS, THE PROCESSING AND REVIEW TIME FOR ABSTRACTS/UNSOLICITED PROPOSALS IS TAKING LONGER THAN NORMAL.  WHEN YOUR ABSTRACT/UNSOLICITED PROPOSAL IS PROCESSED, YOU WILL BE SENT AN ACKNOWLEDGMENT LETTER OR E-MAIL AND WHEN WE RECEIVE A RESPONSE FROM THE PROGRAM AREA THAT IS REVIEWING YOUR ABSTRACT, YOU WILL BE NOTIFIED.  The timeframe for the review of an abstract is typically four to six weeks and a full unsolicited proposal is typically three-six months.  Please refrain from contacting our office before the above processing and review time have elapsed since it will prolong the processing of your submission. If you decide to submit an abstract, please provide your name, address, phone number and e-mail address if applicable. DOE has no obligation to make an award even if the review is favorable, since other program priorities or funding limitations may preclude such actions. ______________________________________________________________________________ The Department of Energy (DOE) makes awards as a result of competitive announcements and solicitations.  An unsolicited proposal (which would fall under a noncompetitive process) may be considered if it represents a unique or innovative idea that would not otherwise be eligible under a known agency competitive announcement. You can access DOE grant opportunities at; http://www.grants.gov/search/search.do;jsessionid=F0QjLvyVnLPBSpw45PyH1yZVkj8LtyhRT6pXGn8ML1cJV4r56NrL!-769876458?mode=AGENCYSEARCH&agency=DOE; competitive announcements for the Recovery Act at www.energy.gov/recovery/funding.htm; competitive announcements for the National Energy Technology Laboratory (NETL) can be accessed at www.netl.doe.business/solicitations/index.html. In order to determine whether your technology has any relevance to DOE’s program objectives and fits any current or planned competitive DOE announcements/solicitations, you may submit electronically (preferred) or in writing a structured/detailed technical abstract/summary of at least 500 words.  The abstract should briefly describe your technology.  If your abstract does not include the (three) criteria below, it will be returnedfor re-submittal. Abstract Sample format:  (Three different paragraphs) 1.  What you propose to do and how (summary of at least 500 words) 2.  Why it is beneficial to DOE 3.  How the technology meets DOE’s mission (www.doe.gov/about/index.htm).  If you have already prepared or would prefer to generate and submit a full unsolicited proposal, you may submit it to our attention.  You may access our Guide for the Submission of Unsolicited Proposals at the following website: http://www.netl.doe.gov/business/usp/USPGuide.pdf.
However, you have the option to submit a technical abstract following the above guidelines to determine potential interest. Abstract submissions must be sent via e-mail to DOEUSP@NETL.DOE.GOV.
The option to submit an abstract or a full proposal does not imply the potential of DOE funding for a research idea.  It merely serves to assist DOE in determining if there is any interest in an idea, concept or technology from our perspective.
Once we have identified the cognizant program area within DOE, we will forward your abstract to that program area for review to determine programmatic interest and whether or not it would fit under any of DOE’s competitive announcements.
If you choose to include trade secret and/or confidential business (proprietary) information in your abstract, it must be marked as specified below.
"USE AND DISCLOSURE OF DATA"
This abstract includes data that shall not be disclosed outside the Government and shall not be duplicated, used, or disclosed-in whole or in part-for any purpose other than to evaluate this abstract.  However, if an award is made as a result of-or in connection with-the submission of this data, the Government shall have the right to duplicate, use, or disclose the data to the extent provided in the resulting award.  This restriction does not limit the Government's right to use information contained in this data if they are obtained from another source with restriction.  The data subject to this restriction are contained in [insert numbers or other identification of restricted data].
If I can be of further assistance, please do not hesitate to contact me.
John N. Augustine
DOEUSP@NETL.DOE.GOV
Date: Fri, 23 Jul 2010 08:04:07 -0400
Subject: Re: new images : power Zone Magnetic r epellency power Zone (M.R.P.Z) invented by Juan Ca rlos Avilés Moran .‏
Mr. Moran, Good morning, It is not necessary to forward on new information, your abstract is currently being reviewed within the DOE program areas. Please allow 4-6 weeks for a review of the abstract, at which time a response will be sent to you via email regarding the reviewers findings. Thank you. Angela    Angela Lanauze, PRC DOE Unsolicited Proposals angela.lanauze@netl.doe.gov
Magnetic repellency power Zone (M.R.P.Z)
invented by   Juan Carlos Avilés Moran .
Alternative energy projects using artificial magnetic monopoles and magnetic repellency to create a continuous rotary motion , invented by Juan Carlos Aviles Moran‏.
new information
using Metamaterials and
anti-magnetic shielding: mu metal, alloys and other diamagnetic materials can create artificial magnetic monopoles
in my project I propose to generate electricity using magnetic repellency and the use of shields to create artificial magnetic monopoles and thus create a rotary motion to move the shaft of a generator and thus generate electric power using the kinetics of magnetic repellency
  Author: Juan Carlos Avilés Moran .
artificial Metamaterials magnetic monopoles, invented by Juan Carlos Aviles Moran‏
The rotating magnetic  kinetics  does not contradict thermodynamics because the magnetic fields that interact with other like polarity magnetic fields do not suffer from variations in temperature is kept stable or constant temperature. remember there is no friction in the rotary system therefore no heat loss or heat gain.
Taking as an example we compare the kinetic energy obtained from the rider to pedal, in comparison with the momentum generated by the shock of the same polarity magnetic fields, (the magnetic fields that interact with other like polarity magnetic fields do not suffer from variations in temperature maintain a temperature that is stable or constant. remember no friction in the rotating system so no heat loss or heat gain). Thus the kinetic energy gained by the force of magnetic repellency is an efficient process. Magnetic fields: magnetic field.
my project could generate electricity at low cost
1. What you propose to do and how ?
Summary  Project  magnetic repellency unit (Alternative energy projects using magnetic repellency and artificial magnetic monopoles to create a continuous rotary motion).
M.R.U (unit of magnetic repellency) summary of the project:
system called magnetic repellency unit taking into account certain parameters that they had not given much thought before:
1) The magnetic repellency when confronted result in the displacement of the lower body mass.
2) Using a ring or circle which is a geometric shape that efficiently manages the energy we can handle repellency directing contained within the ring thus creating a continuous movement as in the ring if there is a succession of artificial magnets either individual or a single that are part of the same polarity magnetic reject or repel the magnets placed on opposite ends of a shaft or rotor inside the ring is give an imbalance or shock of the same polarity magnetic fields, this transfer of a magnet to another created a movement.
3) for the above possible should be taken into account that there will only ring in the magnetic repellency ie we shield or isolate the sides and edges of attraction to achieve this absolute repellency inside the ring
4) in the middle of the rotor shaft or give a twisting force whose strength and speed depends on the mass of the alloy and artificial magnets.
5) the force of torsion will be used to rotate or boost the shaft of a generator and thus generate free electricity and other energy consumption without repellency because it gives me unlimited power.
MIS insights and opinions are personal and while this issue of magnetic repellency unit in its infancy I published on the internet in an attempt to work with an alternative system of electric generation that deserves to be researched and developed.
I firmly believe that the magnetic repellency unit will be in the very near future a reality that is why press it there is still much to know in alloys and insulators and being better than the youth is the future proposal I leave you all to analyze and make their own guesses.
Le annoying again to ask me to analyze magnetic repellency unit (MRU) in a thorough and impartial, I'll tell certain parameters that govern my URM dispocicion or the shock angle between magnetic fields of like polarity is critical in my URM dispocición as well as the magnetic shielding or insulation ie these redirect the rotor, there are multiple variables to consider, such as artificial magnet alloy shield either their rotor or stator forms and surfaces of the magnets are reflected in its magnetic repellency rather than its magnetic attraction. And do not forget the active unipolarity is an important factor seems easy but the MRU is a constant power imbalance repellency than willing to work the right way. PLEASE discuss this project with friends URM professors and professionals. Remember I require myself to U.R.M. that enhances or rotate the shaft of a dynamo The MRU is exactly like the traditional mills used just that URM constant repellency to operate.
magnetic repellency unit name him that way because they have joined into a single design of geometric shapes and physical effects of repellency long time ago trying to create a perpetual motion but until the armor has been discovered it is possible Artificial magnets give a magnified magnetic field proportional to its alloy push if we add the right one that shielding to avoid distortion or deformation of one-pointed path repellency (CRM cascade of magnetic repellency) continually gets a perpetual mobile.
deEE Correspondence EECorrespondence@ee.doe.gov
para"magnetologia@gmail.com" <magnetologia@gmail.com>
fecha25 de julio de 2011 15:17
asuntoYour correspondence with the U.S. Department of Energy
enviado poree.doe.gov
ocultar detalles 25 jul
Dear Mr. Moran:
Thank you for your July 6, 2011 email to the U.S. Department of Energy (DOE) regarding your invention.
The DOE’s Office of Energy Efficiency and Renewable Energy (EERE) works with businesses, industry, universities, and others to increase the development and use of renewable energy and energy efficiency technologies. For a complete list of Funding Opportunity Announcements (FOA) to support the development and demonstration process of these alternative energy technologies, please monitor the EERE Financial Opportunities website at eere.energy.gov/financing/business.html.
The Washington State University Extension Energy Program and the Western Area Power Administration host an “Inventor Resources” page on their EnergyExperts.org website at energyexperts.org/AboutUs/ContactUs.aspx that may be beneficial.
ARPA-E was established within DOE under the 2007 America Competes Act.  ARPA-E's mission is to fund projects that will develop transformational technologies that reduce America's dependence on foreign energy imports; reduce U.S. energy-related emissions (including greenhouse gasses); improve energy efficiency across all sectors of the U.S. economy and ensure that the United States maintains its leadership in developing and deploying advanced energy technologies.  For more information see the ARPA-E website at arpa-e.energy.gov.
Additionally, you can learn more about the patent process for inventors through the United States Patent and Trademark Office at www.uspto.gov.
Thank you for your interest in energy efficiency and renewable energy.
Sincerely,
[size=0pt] [/size][/font]
[size=0pt]Michael Wheeler II[/size][/font]
[size=0pt]SENTECH, Inc.[/size][/font]
[size=0pt]Energy Efficiency and Renewable Energy Correspondence[/size][/font]
U.S. Department of Energy[/size][/font]
----------------------------------------------------------------------------------------------------------------------------[/size][/font]
[size=0pt]
[/size][/font][/size][/font][/size][/font]
magnetologia
I want is to work with U.S. Department of Energy (DOE)   to manufacture units in series magnetic repellency unit
my name is Juan Carlos Aviles Moran
artificial magnetic monopoles, invented by Juan Carlos Aviles Moran
use of metamaterials to create an artificial magnetic monopole
using anti-magnetic shielding: mu metal, alloys and other diamagnetic materials can create artificial magnetic monopoles
Magnetic field increased artificially magnified = optimal alloys
shield the magnets and interrupt lines drag force between the magnets
the shield should have a density greater than block the magnetic field of attraction of the magnets thus establishing a cascade of magnetic repellency is a path as a highway for the magnets of the shaft to be repelled any bad positioning on the ring equals a soft road so the shaft does not rotate magnets
the shield should be proportional to the magnetic field attraction magnets are brought remember although of the same polarity and repel at the same time trying to win this attraction is to be removed
If you can create a continuous movement to generate electric power as knowing if you can I have my plan of magnetic repellency unit and if If you could create a perpetual motion machine.
[/t]
The rotating magnetic  kinetics  does not contradict thermodynamics because the magnetic fields that interact with other like polarity magnetic fields do not suffer from variations in temperature is kept stable or constant temperature. remember there is no friction in the rotary sitem therefore no heat loss or heat gain.
This
Project is based on the physical virtues presented by the magnets (The Stone "lover" It was so poetic name the Chinese gave the natural magnet or lodestone. The stone mistress (tshu-shi) - the Chinese say - attracts the iron , as well as a loving mother brings her children. It is interesting that the French, who inhabit the opposite end of the Old World, the imam gave a similar name, because in French the word "aimant" means "magnet" and "lover". The strength of this love of natural magnets  is very small and it seems naive to the Greeks call the Lodestone "Stone of Hercules." If the inhabitants of ancient Hellas were amazed at both the modest attraction natural magnet.) or magnets (The name of magnetism probably derives from the city of Magnesia in ancient Asia Minor, where it would proceed first natural magnets or Iman, Sweden, in the Ural mountains, in North America, is are large masses of a mineral called lodestone iron ferrous ferric oxide, magnetic oxide, Fe3O4).
    These virtues natural or physical phenomenon rather "Natural" present in the magnet or magnets, are to attract or repel depending on their magnetic polarity, ie the magnet is formed by a set of molecular magnets, neatly arranged with all north poles In the same direction (magnets is to sort the molecular magnets).
    The molecular magnets are grouped one after another in rows that are called magnetic fillets.
    The magnetized iron locks, according to this view, molecular magnets grouped in no particular order.
Imanes elementales orientados al azar ; son propios de sustancias no magneticas. Randomly oriented elementary magnets, are typical of magnetic substances. No existe atracción ; la polaridad de algunos compensa la de otros, quedando el conjunto no magnetico There is no attraction, the polarity of some offsets the other, leaving all non-magnetic
    In a magnet all elementary magnets are oriented in the same way.
    In a magnetic substance the elementary magnets are randomly oriented.
   We could then say that a magnet to a magnet is made up of many electric charges in motion . Microscopic level we think that the atoms that form the magnet behave like elementary magnets arranged and oriented with their respective poles.
    Imam Al breaking a magnet, each piece retains the properties of the magnet original.Un magnet is formed by many elementary magnets.   Each of the pieces obtained by breaking a magnet retains the same properties as the original magnet, also with two poles.
In the steel without imanitos magnetize these atoms are in disorder, so the action of each of them is overridden by the other located on the reverse.
In the magnet, on the contrary, all elementary magnets are arranged, all the poles of the same name are headed in the same direction .
Un imán es pues un cuerpo o masa ferrica con un campo magnético significativo, de forma que tiende a alinearse con otros imanes. A magnet is then a body or mass of iron with a magnetic field significantly, so that tends to align with other magnets.
   The ends of the magnet are called magnetic poles (Poles: The two ends of the magnet where the attractive forces are more intense. These poles are the North Pole and South Pole.)
One of the main features that distinguishes the magnet is the force of attraction or repulsion exerted on other metals, the magnetic lines that form between its polos.Cuando face two or more independent magnets approach each at both ends, if facing the poles have different polarities are attracted (eg conpolo north pole south), but if the polarities are the same (north pole north or south pole south), are rejected.
   When approaching the poles of two magnets, immediately establishing a number of lines of magnetic force of attraction or repulsion, acting directamentesobre opposing poles.  The lines of force of attraction or repulsion established between these poles are invisible, but their existence can be visually checked dehierro sprinkle filings on paper or cardboard and place it over one or more magnets.
Under this premise (magnetic strengths of the magnets or magnets) I base my "General Theory of Magnetic Kinetic" Kinetic understood the enegia displacement generated by a body (The kinetic energy of a body is an energy that arises in the phenomenon movement. It is defined as work needed to accelerate a body of a given mass from rest to the speed it has. Having gained this energy during acceleration, the body maintains its kinetic energy unless its speed changes. For the body back to its state of rest is required work of the same magnitude negative its kinetic energy).
. The adjective "kinetic" energy in the name comes from the ancient Greek word (kinesis "movement").  The term kinetic energy and work and scientific meanings of the nineteenth century.
The kinetics can be best understood with examples that demonstrate how it is transformed from other forms of energy and other types of energy.  For example a cyclist will use energy chemical which provided food to accelerate his bicycle at a speed chosen. . Its speed can be maintained without much work , except for the resistance of air and friction.  The energy converted into the energy of movement , known as kinetic energy but the process is not completely efficient and the cyclist also produces heat .
Taking as an example we compare the energy kinetics of the rider's pedaling, comparing it with the thrust generated by the shock of the same polarity magnetic fields, (the magnetic fields that interact with other like polarity magnetic fields do not suffer from variations in temperature maintain a temperature that is stable or constant. remember no friction in this system rotating so there is no heat loss or heat gain). Thus the kinetic energy gained by the force of magnetic repellency is an efficient process.
Magnetic fields: magnetic field . "
Magnetic fields are usually represented by "magnetic field lines" or "lines of force . "  At any point, the direction of the magnetic field is equal to the direction of the lines of force, and the field strength is inversely proportional to the space between the lines.
the lines of force emerging from one end and bend to reach the other end, these lines can be considered as closed loops, with a portion of the loop in the magnet and away matches.  At the ends of the magnet, where the force lines are closer, the magnetic field is more intense, on the sides of the magnet, where lines of force are farther apart, the magnetic field is weaker.  According to its shape and magnetic force, the different types of magnets produce different patterns of lines of force. The structure of the lines of force created by a magnet or by any object that generates a magnetic field can be visualized using a compass or filings of iron . The magnets tend to be oriented along the magnetic field lines. Therefore, a compass, a small magnet that can rotate freely, will be oriented in the direction of the lines.  Making a compass direction that points to put in different spots around the magnetic field source may be inferred the pattern of lines of force.  Similarly, if iron filings are agitated on a sheet of paper or plastic over an object that creates a magnetic field, the filings are oriented along the lines of force and thus can display its structure.
It is the application of so-called drag lines or attraction of the magnetic field generated by bodies of different magnetic polarity which would slow a perpetual rotation system, which is why the cancellation of these lines of drag (magnetic attraction) gives way to new study kinetics directed magnetic repellency creating artificial monopoles that serve to unify the magnetic fields in order to use repellent collisions between like polarity magnetic fields to produce a continuous motion or mobile "perpetual." the inclination of the rotor magnet inserts it into wedge in the cascade of rotating magnetic repellency Magnetical kinetics thermodynamics does not contradict because the magnetic fields that interact with other like polarity magnetic fields do not suffer from variations in temperature is kept stable or constant temperature. remember there is no friction in the rotary sitem therefore no heat loss or increased calor.Aislante magnetic shield is a forwarder or flow of the magnetic fields, you disable the faces of your selection, making the artificial monopolar magnet.  : without shielding the magnets are turned repel and attract magneticos.Resumen thereby balancing the fields of the project URM (unit of magnetic repellency)? system called magnetic repellency unit taking into account certain parameters that they had not given much before:
. 1) The magnetic repellency when confronted result in the displacement of the lower body mass.
   2) Using a ring or circle which is a geometric shape that manages power efficiently we can manage the repellency contained within the Aro towards thus creating a continuous movement and inside the ring if there is a succession of artificial magnets whether individual or a single that are part of the same polarity magnetic reject or repel the magnets placed on the ends of a shaft or rotor inside the ring will be given an imbalance or shock like polarity magnetic fields, this transfer of a magnet to another created a movement.
3) for the above is possible should be taken into account that there will only ring in magnetic repellency ie we shield or insulate the sides and edges of attraction to achieve this absolute repellency inside the ring
   4) in the middle of the rotor shaft or give a twisting force whose strength and speed depends on the alloy and the mass of artificial magnets.
   5) the force of torsion will be used to rotate or boost the shaft of a generator and thus generate electricity for free and without consumption of other energy repellency because it gives me unlimited power. MIS insights and opinions are personal and while this issue of the unit of magnetic repellency in swaddling clothes, I published on the internet in an attempt to work with an alternative system of electric generation that deserves to be researched and developed.
   I firmly believe that the unit of magnetic repellency will be in the very near future a reality that is why I promote that there is still much we do not know in alloys and better insulation and being that the youth is the future I leave you all the proposed analysis and make their own guesses. Le annoying again to ask me to analyze magnetic repellency unit (MRU) in a thorough and impartial, I'll tell certain parameters that govern my URM dispocicion or shock angle between magnetic fields of like polarity is critical in my URM as well as the disposition from the magnetic shielding or insulation ie these redirect the rotor, there is a multiplicity of variables to consider, such as artificial magnet alloy shield either the rotor or stator forms and surfaces of the magnets are reflected in magnetic repellency rather than its magnetic attraction. And do not forget the active unipolarity is an important factor seems easy but the MRU is a constant power imbalance repellency than willing to work the right way. . PLEASE discuss this project with friends URM professors and professionals.  I demand of myself Remember the MRU that enhances or rotate the shaft of a dynamo The MRU is exactly like the traditional mills used just that URM repellency constant magnetic repellency funcionar.unidad name him that way because they have joined same design geometric shapes and physical effects of repellency long time ago trying to create a perpetual motion but it is until you discover the shielding has been possible to say this is artificial magnet magnetic fields give a boost magnified in proportion to their alloy if we add the suitable shield to prevent the distortion or deformation of one-pointed path repellency (CRM cascade of magnetic repellency) continually gets a movement. Magnetic Field = increased artificially magnified optimal shielding magnet alloys and interrupt lines drag force between the shielding imanesel must have a density greater than block the magnetic field of attraction of the magnets thus establishing a cascade of magnetic repellency is a path like a road along which the magnets of the shaft to be pushed back any bad positioning the ring is equivalent to a road bump magnets so no rotaranel shaft shielding should be proportional to the magnetic field of attraction remember but they are brought magnets the same polarity and repel at the same time trying to attract the attraction is there eliminarSI that you can create a continuous movement to generate electric power as knowing if you can I have my project for the unit of magnetic repellency and if If you can create a perpetual motion machine look visit my blog http : / / energia.obolog. com /
    Shields How can you stop a magnetic field?
How can you stop a magnetic field? Is there anything that can prevent the passage of an electromagnetic field?
You can not completely stop a magnetic field, but you can reducir.Un alternating magnetic field, such as that produced by a transmitter of radio or resulting from an electric current (AC) in a transmission line or transformer may be
   reduced by magnetic fields inside a container are electrically conductive, like a box or cylinder, induce currents in the container. By careful design, these containers can be constructed so that they cancel the magnetic field. These containers are usually made of copper or aluminum . Containers made from most types of steel static magnetic fields reduced (from a permanent magnet) and the fields changing (alternating) time, since the field prefer to travel to through the steel walls and not by the aire.La magnetic permeability is a measure of the amount of magnetism that material available in an applied magnetic field.  For specialized applications, for example, some oscilloscopes tubes, magnetic fields are constructed using materials with very high magnetic permeability.  One of these materials is & μmetal (mu metal), which has a magnetic permeability much higher than steel, copper or aluminum.  Deformation (folding, for example) from & μmetal can dramatically reduce the magnetic permeability.  The heating (annealing) at temperatures above 400 ° C can do to recover the magnetic properties & μmetal special.
Some materials are diamagnetic, which means that when exposed to a magnetic field, these materials in turn induce a weak magnetic field in the opposite direction. Es decir rechazan débilmente a un imán fuerte. That is weakly reject a strong magnet.  Bismuth (Bi) and graphitic carbons are strong examples of diamagnetic materials.  Other weaker diamagnetic materials are the water , the diamond and the tissue alive. Because of this property diamagnetic materials are capable of being used in so-called magnetic levitation, in which objects made of these materials can get to float on a strong magnet.
Explicación. Explanation.
Ferromagnetic materials are those that are strongly attracted by magnetic force. Ejemplos de materiales ferromagnéticos son: el hierro (Fe), níquel (Ni), cobalto (Co), gadolino (Gd). Examples of ferromagnetic materials include iron (Fe), nickel (Ni), cobalt (Co), Gadolin (Gd). The reason that these metals with a strong magnetic attraction lies in the configuration e of its atoms, so that the atoms quickly alienate the magnetic field direction giving rise to domains, or groups of atoms alienated by the magnetic field.  . Some ferromagnetic materials like iron alloys, nickel, cobalt and certain ceramic materials, magnetic properties may retain these for a long time can become permanent magnets or magnetic materials.  In the case of carbon materials nanofoam of carbon has interesting magnetic properties and ferromagnetic.
   Paramagnetic materials are metals that have a weak attraction to magnets. El aluminio (Al) y el cobre (Cu) son ejemplos de estos materiales. Aluminum (Al) and copper (Cu) are examples of these materials. These materials can become very weak magnets, but its attractive force can be measured only with sensitive instruments.  The strength of a Paramagnetic magnet is about a million times smaller than that of a ferromagnetic, so these materials are considered non-magnetic.
Temperature affects the magnetic properties of a material. So paramagnetic materials can become magnetic at very low temperatures, whereas at high temperatures can reach ferromagnetic materials lose their magnetic properties.  The temperature at which a material loses its magnetic properties is called the Curie temperature.
  Author:
magnetologia
Quote from: theshiningeagle on April 07, 2012, 07:18:09 PM
this is realy something bad
but what about George green and the others up up ??
look here
