Juan Carlos Aviles Moran and George green :: The easiest True Magnetic Motors
Started by theshiningeagle, April 05, 2012, 05:09:33 PM
Quote from: enron-r-crooks on November 24, 2012, 11:46:15 PM
Hi Jaun,
Can you please post links to your work ?
I've been following the work of G.V. Nikolaev on Magnetic Vortex and means to produce a Scalar field. He's the author of
Modern Electrodynamics and the reasons for its Paradox by G.V. Nikolaev http://prs-rover.narod.ru/biblitek/book7.html
Secrets of Electromagnetism and Free Energy by G.V. Nikolaev http://prs-rover.narod.ru/biblitek/book6.html
Repetition of the experiences of G.V. Nikolaev a magnet "Siberian Kolya "
Author explains the tech in Russian http://www.youtube.com/watch?v=9-aaz8MuFM0 . The attachment provides the construction notes for experimental setup by Gorlum.
What are the consequences of  Scalar Magnetic Vortex ?
Free Energy Demo #2 Magnet motor
<quote> Basic Parts: Spindle off a Harddrive,8 magnets glued to an aluminum Hub (Don't know what its off of) Placed on an aluminum plate with a hole drilled to support the hub. 6 magnets positioned to "push" the hub magnets With a drive magnet on top With a metal plate to refract the magnetic field. </quote>
Crucially, "drive magnet on top With a metal plate to refract the magnetic field"
Magnetmotor mit Generator Free Energy- Magnet Motor with Generator Energia libre
and
http://www.youtube.com/watch?v=1lC1Jw5Zr44
and
http://www.youtube.com/watch?v=ci0zPKOlIs0
Howard johnson linear magnetic track accelerator video
Gracias
AT LAST! Somebody else knows of Nikolayev. But it's really a shame that you include his great ideas along with hoaxes like that last video. (I don't mean the HoJo track, that's real enough, I mean the guy with the magnet motor "powering" the usual fan and light.)
Nikolayev was Stefan Marinov's mentor; I don't speak much Russian any more but I once had a hard copy of his book and the diagrams were clear and very helpful. His little magnet train example was the inspiration for what I call the Nikolayev or non-contact trailer hitch. I also used his ideas, along with Marinov's, to build a pulse motor version of the Siberian Koliu, and I also constructed and tested a sophisticated version of the original Siberian Koliu motor which Jeffrey Kooistra called the "Warlock's Wheel" when he tested it for Gene Mallove's (RIP) Infinite Energy magazine. This testbed was the most amazing electromechanical device I have ever tested or even seen. As you know it consists of a ring "stator" which is also free to rotate and a central armature made of opposite facing vertical cylinder magnets. When the ring stator is energised by brushes along the outside perimeter, the magnet armature goes one way and the stator ring goes the other way, until a "lock" position of the armature is reached at 90 degrees to the brushes, and the ring stator coasts freely from that point. Not too strange....yet. When the brushes are arranged to contact the ring stator from the _inside_ edge of the ring......... hold onto your hat, Isaac Newton, because __both the ring and the armature rotate in the SAME direction_. Again, the armature locks at 90 degrees to the brushes for as long as current is applied and the ring coasts freely.
I have been able to incorporate this phenomenon into a pulse motor with a special coil winding substituting for the ring stator. Since this is fixed to the frame of the motor, the Warlock's Wheel effect has a different consequence: there appears to be no "back reaction" from the acceleration of the rotor to the stator assembly.
The Nilolayev trailer hitch in 3-d rather than two:
https://www.youtube.com/watch?v=nUihboGkJnE
And I've attached a picture of the Marinov Slab Repultraction pulse motor.
magnetologia
Maximize magnetic repellency and to reduce magnetic attraction or diminish resistance using Artificial magnetic Monopole . Author Juan Carlos Aviles Moran.
In 2009 , The new investigation of Juan Carlos Aviles Moran of the perpetual moving body using magnetic repellency Invented: October 27, 2009  (To give form to the magnetic field using metamateriales to create a continuous impelling magnetic field; to maximize magnetic repellency and to reduce magnetic attraction or diminish resistance using Metamateriales, are created the artificial magnetic monopole what gives like result continuous displacement; Positive feedback or positive refeeding of the displacement by magnetic repellency) the magnetic fields that interact with other magnetic fields of equal polarity do not undergo variants in their temperature that is to say, maintain stable or constant a temperature. we remember does not exist friction in this rotating system therefore there is lost of heat nor no increase of heat The kinetic one can be understood better with examples than they demonstrate how this one becomes of other types of energy and to other types of energy. For example a cyclist wants to use the chemical energy that she provided his food to him to accelerate his bicycle at a chosen speed. Its rapidity can stay without much work, by the air resistance and friction. The energy turned into an energy of movement, well-known as kinetic energy but the process is not completely efficient and the cyclist also produces heat. Taking as an example we are going to compare the obtained kinetic energy of the cyclist when pedalear; comparing it with the push generated by the shock of magnetic fields of equal polarity; (the magnetic fields that interact with other magnetic fields of equal polarity do not undergo variants in their temperature that is to say, maintain stable or constant a temperature. we remember does not exist friction in this rotating system therefore there is lost of heat nor no increase of heat). Being therefore the kinetic energy obtained by the push of the magnetic repellency it is an efficient process. Unit of Magnetic repellency (U.R.M Unit of magnetic repellency is the insertion, compression and extension " Continuous" of magnetic fields of equal polarity; result of " Confront" artificial magnetic poles; Artificial magnetic Monopole is a magnet or magneto to which part of its magnetic field within an alloy has been contained him or alternating layers of Metamateriales leaving it of artificial way with a single active magnetic polarity).
magnetologia
                      ¡¡¡ listen to my  !!!
  • In 2009 , The new investigation of Juan Carlos Aviles Moran of the perpetual moving body using magnetic repellency Invented: October 27, 2009  (To give form to the magnetic field using metamateriales to create a continuous impelling magnetic field; to maximize magnetic repellency and to reduce magnetic attraction or diminish resistance using Metamateriales, are created the artificial magnetic monopole what gives like result continuous displacement; Positive feedback or positive refeeding of the displacement by magnetic repellency) the magnetic fields that interact with other magnetic fields of equal polarity do not undergo variants in their temperature that is to say, maintain stable or constant a temperature. we remember does not exist friction in this rotating system therefore there is lost of heat nor no increase of heat The kinetic one can be understood better with examples than they demonstrate how this one becomes of other types of energy and to other types of energy. For example a cyclist wants to use the chemical energy that she provided his food to him to accelerate his bicycle at a chosen speed. Its rapidity can stay without much work, by the air resistance and friction. The energy turned into an energy of movement, well-known as kinetic energy but the process is not completely efficient and the cyclist also produces heat. Taking as an example we are going to compare the obtained kinetic energy of the cyclist when pedalear; comparing it with the push generated by the shock of magnetic fields of equal polarity; (the magnetic fields that interact with other magnetic fields of equal polarity do not undergo variants in their temperature that is to say, maintain stable or constant a temperature. we remember does not exist friction in this rotating system therefore there is lost of heat nor no increase of heat). Being therefore the kinetic energy obtained by the push of the magnetic repellency it is an efficient process. Unit of Magnetic repellency (U.R.M Unit of magnetic repellency is the insertion, compression and extension " Continuous" of magnetic fields of equal polarity; result of " Confront" artificial magnetic poles; Artificial magnetic Monopole is a magnet or magneto to which part of its magnetic field within an alloy has been contained him or alternating layers of Metamateriales leaving it of artificial way with a single active magnetic polarity).
  • In 2012 perpetual motion using magnetic radiation. Author Juan Carlos Aviles Moran.
Magnetic radiation is free energy, ecological, ie virtually inexhaustible renewable because magnetic radiation is a virtue, is a quality of the magnets. Different kinds of radiation but the magnetic radiation that may emanate magnets radiation is harmless because a magnetic radiation is a magnetic field formed by magnetic force waves. Author Juan Carlos Aviles Moran.
Magnetic radiation can be Redirect, taming, suppressing, containing and deflecting magnetic force waves. Author Juan Carlos Aviles Moran.
magnetic radiation: a radiation magnetic polarity. this radiation polarity attractive or repulsive depending communicate orders waves of magnetic force. Author Juan Carlos Aviles Moran.
The magnet emits Cold radiation by displacement of electrons that spin at high speed around the nucleus of atoms of iron or any material with virtues of ferromagnetism emitting waves of magnetic force without generating heat as the planet Earth, the sun or a live cable that also emit a magnetic field and heat. Author Juan Carlos Aviles Moran.
perpetual motion using kinetic energy and potential energy of the electron to emit waves of magnetic force of permanent continuous or pulsed magnetic repellency so also with the use of artificial magnetic monopole to break the connection or links between waves of magnetic force are issued or irradiated by magnetic poles of different polarity (magnetic attraction). Author Juan Carlos Aviles Moran.
The magnetic field is a magnetic radiation the magnetic force waves . Author Juan Carlos Aviles Moran.
  References and external articles http://en.wikipedia.org/wiki/Perpetual_motion perpetual motion machine of the first kind . perpetual motion machine of the second kind (An exception is the new  investigation of Juan Carlos Aviles Moran of perpetual motion using magnetic repellency and artificial magnetic monopole )
http://www.inventnow.org/patent_certificate/?ph=150ba93b9322a3f3d154723e954c9dd0
http://www.inventnow.org/patent_certificate/?ph=f72b278edda3d16a74d3af9b03eb2449
magnetologia
 Unit of Magnetic repellency "or" Magnetic Repellency Unit (M.R.U) is Alternative energy projects using artificial magnetic monopoles and magnetic repellency to create a continuous rotary motion. This project propose to generate electricity using magnetic repellency and the use of shields to create artificial magnetic monopoles and thus create a rotary motion to move the shaft of a generator and thus generate electric power using the kinetics of magnetic repellency. created by Juan Carlos Aviles Moran.
definition: Unit of magnetic repellency "or" Magnetic repellency unit is the insertion, compression and rebound "Continue" in the same polarity magnetic fields, the result of "confrontations" artificial magnetic monopoles. Author: Juan Carlos Aviles Moran.
http://www.inventnowkids.org/patent_certificate/?ph=150ba93b9322a3f3d154723e954c9dd0
