Juan Carlos Aviles Moran and George green :: The easiest True Magnetic Motors
Started by theshiningeagle, April 05, 2012, 05:09:33 PM
magnetologia
The magnetic field is a radiation of Waves magnetic force (magnetic force waves)
_the magnetic field is a radiation of Waves magnetic force (magnetic force waves).Author Juan Carlos Aviles Moran.
_the magnetism is produced by Waves of magnetic force (magnetic force waves) .Author Juan Carlos Aviles Moran.
nievesoliveras
@moran
I thought you were dead!
Somebody told me you passed away.
It is nice that youre alive and kicking.
Jesus
magnetologia
Magnetism is produced by Waves of magnetic force (magnetic force waves) .Author Juan Carlos Aviles Moran.
The atoms in the magnet add their magnetic fields and thus enhance overall is causing an exponential growth that produces a chain reaction and this releases energy in waves of magnetic force thus creating the magnetic field . Author Juan Carlos Aviles Moran.
magnetic attraction is the unifying force of atomic magnetic fields. Author Juan Carlos Aviles Moran
Compression between Waves of magnetic force  same polarity  is "magnetic repellency".Author Juan Carlos Aviles Moran.
Connection and Annexation Waves of magnetic force  different  polarity is "magnetic attraction" .Author Juan Carlos Aviles Moran.
magnetic repellency is the compression and extension of the magnetic field to resulting of confronting magnetic fields to the same polarity what looking back to the original form . Author Juan Carlos Aviles Moran (student Magnetología  Magnetology).
Magnetic attraction is the connection and annexation of individual magnetic fields produced by magnetic fillets (set of molecular magnets, neatly arranged, the molecular magnets are grouped one after another in rows that are called magnetic fillets due to reorganization of the elementary magnets) thus creating a force field of positive (+ adds magnetic fields) that will attract and join the magnetic fields of different polarity Author Juan Carlos Aviles Moran (student Magnetología  Magnetology)
Magnetic attraction definition -magnets attract magnetic fields because the lines of force connect with other lines of force of magnets of different polarity "Conection" the magnets is the connection lines of force traveling in space-time to join other lines of force of different polarity attract the magnet to create a single magnetic field and so aligned with the other magnet magnetic fillets (align and order the molecular magnets) and close or balance the magnetic field. Author Juan Carlos Aviles Moran (student Magnetología  Magnetology).
magnetologia
perpetual motion using magnetic radiation. Author Juan Carlos Aviles Moran.
Magnetic radiation is free energy, ecological, ie virtually inexhaustible renewable because magnetic radiation is a virtue, is a quality of the magnets. Different kinds of radiation but the magnetic radiation that may emanate magnets radiation is harmless because a magnetic radiation is a magnetic field formed by magnetic force waves. Author Juan Carlos Aviles Moran.
Magnetic radiation can be  Redirect, taming, suppressing, containing and deflecting magnetic force waves. Author Juan Carlos Aviles Moran.
magnetic radiation: a radiation magnetic polarity.
this radiation polarity attractive or repulsive depending communicate orders waves of magnetic force. Author Juan Carlos Aviles Moran.
The magnet  emits Cold radiation  by displacement   of electrons that spin at high speed around the nucleus of atoms of iron or any material with virtues of ferromagnetism emitting waves of magnetic force without generating heat as the planet Earth, the sun or a live cable that also emit a magnetic field and heat. Author Juan Carlos Aviles Moran.
perpetual motion using kinetic energy and potential energy of the electron to emit waves of magnetic force of permanent continuous or pulsed magnetic repellency so also with the use of artificial magnetic monopole to break the connection or links between waves of magnetic force are issued or irradiated by magnetic poles of different polarity (magnetic attraction). Author Juan Carlos Aviles Moran.
the magnetic field is a magnetic radiation the magnetic force waves . Author Juan Carlos Aviles Moran.
enron-r-crooks
Quote from: magnetologia on November 23, 2012, 04:17:28 PM
Hi Jaun,
Can you please post links to your work ?
I've been following the work of G.V. Nikolaev on Magnetic Vortex and means to produce a Scalar field. He's the author of
Modern Electrodynamics and the reasons for its Paradox by G.V. Nikolaev http://prs-rover.narod.ru/biblitek/book7.html
Secrets of Electromagnetism and Free Energy by G.V. Nikolaev http://prs-rover.narod.ru/biblitek/book6.html
Repetition of the experiences of G.V. Nikolaev a magnet "Siberian Kolya "
Author explains the tech in Russian http://www.youtube.com/watch?v=9-aaz8MuFM0 . The attachment provides the construction notes for experimental setup by Gorlum.
What are the consequences of  Scalar Magnetic Vortex ?
Free Energy Demo #2 Magnet motor
<quote> Basic Parts: Spindle off a Harddrive,8 magnets glued to an aluminum Hub (Don't know what its off of) Placed on an aluminum plate with a hole drilled to support the hub. 6 magnets positioned to "push" the hub magnets With a drive magnet on top With a metal plate to refract the magnetic field. </quote>
Crucially, "drive magnet on top With a metal plate to refract the magnetic field"
Magnetmotor mit Generator Free Energy- Magnet Motor with Generator Energia libre
and
http://www.youtube.com/watch?v=1lC1Jw5Zr44
and
http://www.youtube.com/watch?v=ci0zPKOlIs0
Howard johnson linear magnetic track accelerator video
Gracias
