High RPM to Low RPM, Motor-Generator: Public Discolsure - The Real McCoy
Started by bradagilah, April 15, 2012, 04:53:16 PM
4Tesla
Quote from: bradagilah on April 16, 2012, 02:22:34 AM
Thanks.
The thread is very active on the ATS forums:
http://www.abovetopsecret.com/forum/thread830762/pg1
Check the thread out, to read up on what everyone else has said, and what I have replied.  Also, I will be checking back and fourth between the two forums.
-Pierre
I am registered there on ATS.. I no longer post due to all the trolls and rude mods.. I would focus on the ou forums.
I started a thread over at OUR.. http://www.overunityresearch.com/index.php?topic=1417.msg22693;topicseen#msg22693
Also get in contact with Sterling over at PESWiki.. http://www.peswiki.com/index.php/Main_Page
When posting on ATS you must be sure you're made of Steel, it contains a lot of armchair scientists and people who can endlessly debate about nothing.
Since you're open to visits  imo there's no more need to waste your time on explaining the concept any further, it's quite straightforward already. IF you're going to invite someone please make it public as well as inviting strangers can also be dangerous. Be prepared for a lot of scrutiny and I hope the invited or you can record the visit too.
bradagilah
Thanks broli.  That's a good idea, and I agree with your assertation going forward.  I need a bit of R&R now, after, having put up a fight with everyone across different forums.  But I'll proceed to make arrangements with everyone. Stay tuned.
Based on this motor: http://goo.gl/I0IqJ
And this generator: http://goo.gl/rqopq
I did a quick analysis on paper. I'm not making any conclusions but from what the data sheets provide and from the simple equations you can see what I get from the file attached.
Is this also how you did the power calculation to find that OU factor? If someone notices a slip somewhere please do comment.
Edit: I believe I already see an error in input power, I forgot it was a 3 phase motor meaning the equation needs a multiplication by the squareroot of 3. Which gives a total input power of 6124.47W making the setup not so OU anymore :p.
bradagilah
You thinking about it intently.  Very good.  Consider this also, the generator head is also three phase, so it experiences the square root of 3 lift in power, on top of the 5kW.
