Alternative/Free Energy Group Starting In Hampton Roads
Started by travin69, June 15, 2012, 09:42:49 AM
jonifer
you would not touch Lenz, he is invincible. Such models are well calculate in FEM programs
travin69
jonifer
To date, no known example of Lenz's rule violation. Coil with a variable cross-section, the bifilar coil, piramid coil, superconductor coil and any form of core or material etc. - total energy ballance.
travin69
Jonifer,
Thanks for the try but I just don't have the knowledge to understand what you are telling me.  I am a trial and error kinda person when it comes to electrical engineering/magnetic physics.
From my standpoint on building an overunity motor, I look at input energy vs output energy (actual power out, not mathmatically calculated).  At the current moment, my test motor draws 0.6 - 0.7 amps at 24 volts; no matter what load is placed on the motor, it stays at 15-16 watts.  I measure the actual energy that is drawn from the battery, through the power measuring device, into the motor controller, ie gross power into the motor.  Once the generator is done (looks like next Monday), I will connect it to the motor shaft and place a dc resistance load on the generator.  The same type of power measuring device will be between the generator and the load.  I will then compare the two and calculate my efficiency.  I want real world figures that include all the inefficiencies and tolerance ganging issues.  I feel this is much more indicative of performance, as it is actual real performance.
Once I test the unit, I will optimize each piece based on my research and design abilities.  My plans include: magnetic bearings, top quality electrical iron core material (vice 1018 CRS), variations of bifilar and litz wired coils, parallel wound coils, core shape variations, and other changes.  Each change will then be tested to see how the input/output power levels are affected.  At this current moment, I feel that the core material, shape, and coil windings are the key to reaching overunity in my case, though more specifically the coil windings.  I see the way to overunity via coils with bifilar/parallel windings, as this affects the power input (I can lower the power and keep the amps the same).  This combined with an optimal core material is as good as I can get.  If it doesn't work, then it doesn't work.
I am extremely excited about the results next week.
Thanks,
Daniel
jonifer
no chance, in all conceivable ways this is done, max COP=95% for modify motor-generator system.
