REAL WORKING MAGNET GRAVITY WHEEL !! It WORKS !!
Started by gadgetmall, August 31, 2012, 09:56:40 PM
truesearch
Anything new on the original thread topic of the "Magnet/Gravity Wheel"?
truesearch
golfinj98
Search youtube for "Living Energy Machine".  Pretty interesting device
johnny874
Quote from: helloha on November 12, 2012, 08:28:15 PM
HAPPY FLYING
wing suit skydive http://www.youtube.com/watch?v=5N9t5qOSzCU&feature=related
http://www.youtube.com/watch?v=jLWnS3gFJoM&feature=related
jetpack http://www.youtube.com/watch?v=kSgrzMQv2Mc&feature=related
or DIVING
http://www.youtube.com/watch?v=h-7RlL3YtiQ&feature=g-vrec
http://www.youtube.com/watch?v=2mQl84elXT4&feature=related
or search for these events
Birdman Rally
Flugtag
  Those flying squirels are pretty cool. One thing I've given thought to is that with a bird, the weight of it's own wing might help it to fly. Just like with perpetual motion, conserving energy by using the potential that is there more efficiently allows for things that we just accept unless we are crazy as those guys.
tinu
Quote from: pree5 on November 10, 2012, 10:55:35 AM
how to buy this prototype? ??? ?
I don't know about buying it but why not building it?! It's very simple yet quite clever.
Here is my version about how it works:
Setup: non-magnetic big wheel, ferromagnetic ball.
Blue-red handheld "magnet" is actually a permanent magnet and a coil powered by a small oscillator or on-off switch (probably at several hundred hertz) plus a battery (of course), all concealed inside.
Initially, considering the coil not powered, the permanent magnet holds the ball in place, in equilibrium on the rim of the big wheel. There are no forces to create angular momentum thus no rotation. :(
However, by powering the small coil so as it works additive to the existing magnetic field of the permanent magnet, the coil will now attract the ball to a slightly higher equilibrium point. The ball will always get there by spinning because that's the least energy-consuming movement (it's pretty much similar to why a ball will spin on the floor when thrown away, instead of translating on the floor; simple stuff – hope you've got it).
When ball spins and rises toward the new equilibrium point, the big wheel spins too, due to friction. Interesting enough, both ball and wheel spin in the same direction. That's a slight issue since in order the whole motor/setup to run as presented, when coil is shut of, the ball has to at least slightly slide downwards against the now turning wheel or otherwise the big wheel would not rotate as seen. It's because of angular momentum conservation but I suppose the readers already understand it or they don't care much.
Nevertheless, the setup although inefficient as a motor is pretty clever, very fun and easy to build!
Good luck and if I got it right, please post here or send me pictures with your setup.
Best regards,
