Siphoned Heron's fountain
Started by Ghost, September 01, 2012, 11:02:04 AM
johnny874
 in Heron's fountain, the water displaces the air. with what I showed, the water spills into the chamber having water pumped out of it, the air mintains a constant pressure
Ghost
i just had another crazy idea using just one container. by far the best i think.
pulp
Hello what do you think about my idea do you think that the liquid in the containers will balance on the same level or will continue to flow is it possible acording to you?
Qwert
@pulp, of course water will flow here if the level is fixed. I think you want to show that the level is pivoted and its heavier side goes down; so, here the heavier side as you see is in wrong side of the level; it always gets "lower", never "higher".
Ghost
pulp,
all the water containers will end up having the same level of water and the arm holding the containers will end up horizontally. will not work.
or the arm will completely tilt and water will over flow and leave you with one container full and two container empty. will no work.
sorry.
