Probality of God
Started by Newton II, September 14, 2012, 01:33:36 AM
gravityblock
Quote from: eatenbyagrue on November 08, 2012, 06:24:29 PM
So you assert.  I assert that there is no spirit, and the brain is all there is.  Why is the brain alone, without your Spirit, not capable of providing us with the human experience that we know?  There is much evidence for why it does, and zero evidence of any spirit.
So, why do you think this?
"As above, so below" is the absolute proof for the existence of God!  You failed to absorb this into the very fabric of your soul.  I didn't assert, I just didn't give you all of the information in my prior post.  The two most prominent bodies in the heavens, the sun (the greater light) and the moon (the lesser light), shadowed the two most prominent structures in the bible, Noah's Ark (the greater structure) and the Ark of the Covenant (the lesser structure).  By taking the area of Noah's Ark we'll find the numerical diameter of the sun.  By taking the area of the Ark of the Covenant we'll find the numerical diameter of the moon.  In addition to this, the two pillars Solomon built also shadowed the two great lights.  There's more, Joshua circled the city of Jericho once a day for six days, and the number of degrees they traversed is equal to the numerical diameter of the moon.  Jericho means "city of the moon".
Watch the video on the Firmament for additional information.  I'll give you fair warning before you watch the video, and that is to be prepared to embrace your true God and Creator.  I'll be leaving this discussion, because if you reject this amount of evidence I have presented to you so far, then there is no hope in convincing you otherwise, unless God chooses to do so.
Take care and God Bless,
Gravock
ramset
Oh you guys need an intermission
Here a Thane Heinz Toroid with Don smith accesories
Running a load connected to No power source
http://www.youtube.com/watch?v=mzE-p0GJb_Q
From Here
http://www.energeticforum.com/renewable-energy/4864-donald-smith-devices-too-good-true-258.html#post213894
Thx
Chet
Thanks Grandma
eatenbyagrue
Quote from: gravityblock on November 09, 2012, 03:31:46 AM
Gravock
I watched the video with high hopes of seeing actual evidence.  I was disappointed.
ramset
Eaten
I will tell you this...........
At some point in this life before you leave us.That mustard seed will twitch
and you will itch.
Whether you resist the urge to scratch that itch will be up to you........
@Chris
Yes you need to keep searching my friend !
Scratch that itch..........
Hoptoad
So whatcha think of the Thane Heinz Don Smith self running Flavor shavor Movie
Here  http://www.youtube.com/watch?v=mzE-p0GJb_Q
Thx
Chet
Thanks Grandma
Bruce_TPU
Quote from: ramset on November 09, 2012, 09:32:46 AM
Eaten
and you will itch.
@Chris
Hoptoad
Thx
Chet
Interesting Chet, but honestly I could not make heads or tails of what he is doing.  I could not see any toroid, and there are so many wires going anywhere, even if by some miracle it is legit.  We need to wait to see if there is a circuit.  Seems to me that he is only using the negative of the battery?  Thoughts?
Cheers,
Bruce
