Probality of God
Started by Newton II, September 14, 2012, 01:33:36 AM
gravityblock
1.)  The Acceleration of earth's Gravity  x  earth orbit Time (exact lunar year)  =  the Velocity of Light.
(9.80175174 m/s2 x  30,585,600  s  =  299,792,458 m/s)
2.) The Acceleration of earth in orbit  x  earth orbit Diameter  =  the Velocity factor of Light.
(.00100338656876 x  3298,760,616,894.579  =  299,792,458)
3.)  When the orbit Circumference of  earth (AZ2) is calculated at 938,646,991,071.036 meters and its orbit Acceleration as .00100338656876 m/s2, earth's orbit Velocity then reveals itself as exactly 30,689.1802374659 m/s.
Hence the following list of extraordinary mathematics unfolds;
a)  Orbit velocity2  /  Pi  =  Speed of Light.
b)  Planet Density2  x  4 Pi  =  Speed of Light.
c)  9,768.669468531722 x  Pi  =  Speed of Light.
d)  Gravity Acceleration  x  Orbit Time  =  Speed of Light.
e)  Orbit Acceleration  x  Orbit Diameter  =  Speed of Light.
f)  Orbit Velocity  x  2  x  planet Density  =  Speed of Light.
g)  Orbit Velocity  x  9,768.66946853172  =  Speed of Light.
h)  Surface Area of orbit sphere  x  planet Density  /  orbit Radius  =  Speed of Light.
i)  Orbit Diameter  /  9,768.66946853172  =  Orbit Time.
j)  Orbit Distance  /  9,768.66946853172  /  Pi  = Orbit Time.
k)  Gravity Acceleration  /  9,768.66946853172  = Orbit Acceleration.
l)  9,768.66946853172  x  Pi  =  Orbit Velocity.
m)  Gravity Acceleration  x  (Orbit Time / 9,768.66946853172) =  Orbit Velocity.
(  9,768.66946853172     =     2  x  earth Density     =     4,884.33473426586 kg/m3     =     4.884 g/cm3  )
Gravock
gravityblock
The mathematics also holds true for the planet Mars.
Mass  =  6.41693 x 1023 kg
Volume  =  1.6708399703069 x 1020 m3
Density  =  3,840.54135287503
Orbit Radius  =  227,936,640,000 m
Orbit Diameter  =  455,873,280,000
Orbit Acceleration (A)  =  .00040658431227
Orbit Time (Z)  =  59,350,132.9780459
Orbit Velocity (AZ)  =  24,130.8329999134
Orbit Circumference (AZ2)  =  1,432,168,147,415.88
Gravity Acceleration  =  3.123
2 x planet Density  =  7,681.08270572251
Centripetal Acceleration  =  .00255464457697
When the orbit Circumference of Mars (AZ2) is calculated at 1,432,168,147,415.88 m and its orbit Acceleration as .00040658431227 m/s2 its orbit Velocity then becomes exactly 24,130.8329999134 m/s.
Mars' orbital Acceleration (.00040658431227) multiplied by mars orbit Diameter (455,873,280,000) =  185,350,924.030313.  This number divided into the speed of light is equal to; Earth Density2  /  Mars Density2
b) Orbit velocity2 / Pi = 185,350,924.030313.
c) 7,681.082705722512 x Pi = 185,350,924.030313.
d) Gravity Acceleration x Orbit Time = 185,350,924.030313.
e) Orbit velocity x 7,681.08270572251 = 185,350,924.030313.
f) Orbit Diameter / 7,681.08270572251 = Orbit Time.
g) Orbit Distance / 7,681.08270572251 / Pi = Orbit Time.
h) Gravity Acceleration / 7,681.08270572251 = Orbit Acceleration.
i) 7,681.08270572251 x Pi = Orbit Velocity.
j) Gravity Acceleration x (Orbit Time / 7,681.08270572251) = Orbit Velocity.
( 7,681.08270572251 = 2 x Mars Density = 3,840.54135286125 kg/m3)3.840 g/cm3
Gravock
gravityblock
As you may have noticed, the speed of light calculated on the earth is different than the speed of light calculated on mars.  You can't deny the mathematics, so lets assume for a moment it is correct and try to confirm it.  According to Ioannis Xydous publication, titled, Secret of the Electron-Positron pair, "there's a reduction in the E/M wave's velocity when entering an Electrostatic Field".  Assuming for a moment the true velocity of light is 0 and we're moving past stationary light via expansion acceleration, then we can re-word the statement made by Xydous to better reflect the true reality of things and say, "there is a reduction in expansion acceleration when entering into a pressure of electrical mass from stationary light.
This Pressure decreases according to the inverse-square law.  This is the reason that gravity also decreases inversely as we move out into space.  In other words, an object's expansion acceleration rate decreases according to the inverse-square law as we move away from the sun.  Remember, expansion acceleration and orbit are One!  To support the work of Xydous, we can turn to Frank Znidarsic who says, "the speed of light decreases to match the speed of mechanical waves in the electronic structure of the atom".
299,792,458c / 185,350,924c = The Golden Ratio of 1.618.  How is there a golden ratio in the expansion acceleration rate between mars and earth?  This shows an Intelligent Design of a Creator!  God is the ultimate mathematician.  We see this everywhere.
Gravock
WilbyInebriated
Quote from: gravityblock on November 15, 2012, 07:03:43 AM
if by 'god' you mean odin allfather... then yes, you are correct.
eatenbyagrue
Gravock
I think you need more exposure to opposite points of view.  You can start with Krauss's Universe from Nothing:
http://youtu.be/EjaGktVQdNg
