0 Members and 446 Guests are viewing this topic.
Quote from: NickZ on July 15, 2015, 10:55:49 AM
Active 500w
ใช้งานได้ 500w
"Be careful. Something could catch fire. 100W incandescent light bulbs can get really hot".
  5 100w bulbs are going to catch fire? From a 27w input???  Or what is going to catch on fire?
My brain is going to catch on fire, just from looking at that allegedly "high voltage" device, incorporating delicate tuning of LC circuits ....
Yes, 100W incandescents can get really hot, especially when running at full rated power. They are also pretty darn bright... when running at full power.
Where did you get "27w input"? It looks to me like the meter is showing 1.12 amps coming from the Thailand 220V mains. Plenty enough to run a bank of "100W" Chinese bulbs at reduced brightness.
AlienGrey
Re Tomtech 29
Now the diagram you have posted is interesting, Have you tried connecting a scope to it and looking at the wave form ? the reason I ask is because the T1000 Akula circuit shows pulse on pos and neg wave, do you see that ? Tomtech ?
Now if you look at the 'sinuho diagnosium' only it looks to me to trigger on one side of the wave form, do you see that ?  thier is also another problen you need to test, is it a square wave on a scope ? ie 50 / 50 wave form ? you need to look at the wave form !
It's that you need to check out if you are serious. Just cus it's posted on here does not mean it's going to work or it's not full of bug's ;)
T-1000
Quote from: TinselKoala on July 15, 2015, 11:15:14 AM
Try to run them on ultrasound frequency range, not 50/60Hz. Then you can see how much heat is wasted on bulbs and how much light is emited. The frequency is a key there :)
T-1000
Quote from: AlienGrey on July 15, 2015, 11:32:39 AM
Ruslan used only positive trigger wave for Tesla coil pulses.
AlienGrey
T1000 ;)
Next question is with phase lock loop, notice it has no divide by 100 logic to lock the phase of the tesla coil 1.5 Mhz to the 15 khz, in Tomtechs circuit, to hows that work ?
