0 Members and 446 Guests are viewing this topic.
T-1000
Quote from: AlienGrey on July 15, 2015, 11:56:19 AM
Next question is with phase lock loop, notice it has no divide by 100 logic to lock the phase of the tesla coil 1.5 Mhz to the 15 khz, in Tomtechs circuit, to hows that work ?
This is worked out in other way there:
The target wave on grenade coil was set to 37.5m
So the Tesla coil 1.5MHz translates to  199.86m which is 150m (x4) from Grenade coil plus 49.86 from grounded cable.
And 15kHz for induction heater LC resonance is deviated on 1/100th from Tesla coil: 1500kHz / 100 = 15kHz.
The 1.5mHz driver is fired up for very small duty cycle right after peak on 15kHz with targeting cross over between transformer amps draw drop timing on induction heater circuit and the output current rise from grenade coil.
AlienGrey
T1000
Thanks for the information one other thing is the gap between the Tesla coil or Katcher, and the start of the grenade coil critical or is one of them on a saleable-based thin plastic overhead projector type material that can slide up and down for fine tuning.
NickZ
    TinselKoala:
   I think that you are supposing that the picture you re-posted is of my device? It's not.
   The AC PS unit has an input source of 120v OR 220v AC, providing for a 24v or 12v DC, 10amp output.
   The 5 100 bulbs or something else, almost catching on fire?  Maybe, but I doubt it, especially when only partially lighting the bulbs.
   Why do you guys have to ridicule every ones project and hopes?? Do you get off on it? Or What?
   How about you showing us how it's really done, then.  Without needing to use Hoppy's cop-out idea, x-wire, and batteries.
   At least there are people here attempting to make this Ruslan device replication. Even though there is ridicule and naysayers contributing to more than a 100 posts, but, doing nothing toward developing and improving this project....
  Here are a couple of fairly recent pictures of MY device, including the ferrite fly-back cored feed-back loop that I'm currently using for now.  Yes, I could use some more of those colored clips, for sure.
Acca
TK is that destroyer of free energy ... or did you not know !
Only to save you from your self wasting time and money ...
Alternative motive is always half truth ridden..
Acca...
Dog-One
Quote from: T-1000 on July 15, 2015, 12:04:25 PM
So how many actual 1.5MHz pulses does that work out to be?  And do those pulse come through at a 50% duty cycle?
I'm using a SN74LS221 to get phase delay and pulse width from the 15kHz sync of the push-pull.  I then take this into an AND-gate combine it with the 1.5MHz oscillator and run the output to the gate driver.  From what I can see you only get a dozen or so pulses at the crossover point unless you make the pulse width rather wide.
