Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
joaouchoa and 260 Guests are viewing this topic.
skywalker66
Quote from: Jeg on March 28, 2016, 07:25:38 AM
Nice and correct calculations. It is just that when you'll attach your antenna, your frequency will go down a lot and you 'll need to unwind again almost the half of your coil. This antenna is very "heavy" for high frequency targets like 1.5MHz and above.
Hi !
I know that part. Will see what frequency it have with and with out antenna when I will have some
time for testing it. Just now I not aim for a specific frequency to tune for. I just will do some tests with it as is it now, and will see.
AlienGrey
Quote from: T-1000 on March 28, 2016, 01:00:11 AM
Just ignore trolling and attacks and please keep focused ;)
Do you have any comments on concept diagram I shared? Maybe add some valuable information to it?
Cheers!
over the years snippets of info have appeared on here and other places if you make your grenade coil 4 to 1 ie 38 m and 19 m that's only half wave (confusing).
I have a miniature grenade same ratio, I notice its resonant f is about 16mhz about double the one everyone else is using, I made it for tests as I had no 50 mm drain pipe or 2.5 mm cable at the time. Anyway if I drive it at about 15 khz I get a small return of power but if I alter the f closer to a multiple of the Schumann res power through becomes highly efficient,  C res coupling is 0.47uf my guess is if i can alter the C to get F to bang on Schumann res, in the coil  anyone else tried this ?  I returns a very, very bright white light for the same power as one driven by 10w.
Also I'm only getting efficiency nothing free before anyone gets too excited power wise but the quartz bulb does like HF far better than DC or 50 hz.
Hoppy
Quote from: AlienGrey on March 28, 2016, 07:45:12 AM
That's interesting about the Schuman frequency. If you get the power and frequency right, you will be able to completely fracture the two legs of the quartz filament cleanly away from its glass base without burning it.  :o
nelsonrochaa
Quote from: skywalker66 on March 28, 2016, 12:49:13 AM
Nelson, I only hope you will not end up enclosed in your room because us, ignorant people, do you ?.  :o  ;D
It will be very sad.  :(
Good luck with your very private whatever you do.
He most likely use a SEC exciter by Ronald R. Stiffler. See schematics attached.
Not so clever.  He also copied others ideas
Hi ,
You feel like  ignorant ? You misunderstood my words with your interpretation if you feel that .
For sure i'm will not end up enclosed in a room ;)  , because actually i gain the privilege of work on that area i a real job with people with same knowledge's, and that is a privilege to me .
And only to your information i not copy anything by anyone in my work ; even based in Tesla work and Moray , my circuits are made by my own head, and that make all the diference , between me and  some folks .
It need to understand old texts and  how to adapt to present reality of electronic and for that need to work on benk not only blalallalala understand that ?
Like i told before , even when someone give good information some people run spitting in the dish they eat .
People are free to decide what is best to itself , even maintain in ignorance .
My intent is only give a response about one particular subject that someone talked in some posts ago not hurt your feelings. sorry if i make you feel bad .
PS- About the diagram that you share forget them because is only nothing for what people search, is only to people that initiate in this area of research start scratch .
I could with only some milivolts of input have better  results than the circuit you share can do .
Have a good work ;)
Hoppy
Quote from: nelsonrochaa on March 28, 2016, 09:25:50 AM
Have a good work ;)
This is now degenerating into a "my circuit is better than your circuit" na-nana-naa-nah type thread.  :(
