Seven times more energy output than input: Power Multiplier Device
Started by Russell Lee, October 04, 2012, 03:20:25 PM
Neo-X
I calculate it again this time with greater accuracy and i found that when you lift an object more energy is being used than when an object was falling no matter how fast or slow it is. This means the theory wasn't true then why some inventor can make a perpetual machine powered by gravity?
CuriousChris
You are right I did not understand much of what you said.
If both masses are the same on the rope and pulley then other factors will decide which leaves the ground first. pulley friction is the most likely to effect the outcome.
Quote from: webby1
The normal view on all of that is that gravity is conserved, that force in equals force out and work in is equal to work out, but a window of interaction can open, an interaction that does not use the constant force created by mass and gravity the same in both directions of motion, there is no law or rule that says you must use the changed conditions in the same way and for the same purpose, be creative.
Still don't understand it.
Perhaps you can give an example of being creative?
CuriousChris
you choose. I wouldnt know which is the best example of what you are trying to convey
andrea
Quote from: Neo-X on October 18, 2012, 10:43:20 PM
if u bend the thin tube at the mark 1kg, the water will flow
I don't understand. May you do a draw? Or explain it better. Thanks
Russell Lee
  I feel I hould again explain the aspect of this Power Multiplier Device that allows it to produce excess energy.
  When the weights are being brought up the chain by the small motor, these weights, hanging on the bracket, are still producing the 500+ pound pull on the chain as they ascend.
  This means that the generator is still producing the fulll charge, it is just that this charge is being used by the small motor on the bracket. Since, will the entropy involved, the generator is not producing enough power to supply all of the motor's needs, a small amount of 'entropy' power is drawn from the battery, for 30 seconds.  Then when the weights reach the top, the motor shuts off, ending the small entropy power drain on the battery.  Now the weights descend for 3 minutes charging a full charge into the battery for the full 3 minutes.  So the focus is on the battery.  At first it experiences 30 seconds of a small amout of entropy power drain, then 3 minutes of a full charge.  One amount of time for a small charge decrease, and six times that amount of time for a full charge increase=excess "free" energy.
Quote from: CuriousChris on October 20, 2012, 05:40:31 AM
