marathonman
Quote from: MenofFather on March 27, 2014, 06:39:36 AM
Yes, secondaries I make bigger, somthing like in Hein transformer. To magnetic flux go from primary to secondaries, but not go from secendaries to primary.
I was refering to the Primaries bigger and the Secondaries smaller, opposite of what you have now.??????
dieter
Actually, I did use diodes when I used the two separated halfwaves, but it didn't seem to neutralize the back mmf/emf ...
So I got a question: When a B field collapses, it induces a current of reverse polarity. but if this current can't flow (due to diodes), will the B field persist?
Isn't there a contradiction, whether the collapsing B field induces the back EMF, or the Back EMF causes a Back MMF that looks like a "collapsing field"?
Basicly, is there a diffrence in the effect of the collapsing B field depending on whether a current may flow in the coil or not?
PS. marathonman, good point about the 50% takeover...
shadow119g
Welcome MenofFather
Shadow update
I think my transformers are working properly but at a low voltage.
I also think it is because of the commutators I built. I am getting
about the same results from both the 32 and 16 contact versions.
I really don't know why the voltage is low.
The only encouraging thing is that for each transformer group of
three, the voltage increases as I measure voltage from the first
group through the fourth group.
The following is the voltages for each group of three transformers:
Group 1 = .4 analog meter .2 digital meter
Group 2 = .95                   .6
Group 3 = 1.55                1.1
Group 4 = 1.95                1.6
I have changed the air gap from about .035 to .008 and .002
the last I had to leave the clear office type tape in the gap.
The readings did not change between the .008 and .002
I am using a lawn mower 12 volt lead acid battery sometimes
with a trickle charger.
I machined the mild or hot rolled steel to within a .001 tolerance.
the three pieces of steel are through bolted at the top.
The primary legs are two times the length of the bar the coil
mounts on.
Any ideas why my voltage is so low?
Oh, I have a little over 100 turns of #18 = 1.023mm wire
the same length and turns on all coils.
Shadow
dieter
Shadow119g,
This sounds great. The wire seems a little thick and the n-of turns a little low. With a 1 mm wire I would expect a coil at least 1" x  4", also as a rule of thumb the dc resistance should not be too low, eg.  (12v x 12v)/ 14 ohm = 10 watts dissipation, which is a lot for a 12 v battery. Of course, just reactive, but nonetheless.
The contact of the commutators, is it sparky? That may give you lots of voltage peaks, but not a very long real contact time, resulting in less total current, which may lead to extensive dropping of voltage in the primary.
Maybe try to use a high voltage low capacitance cap accross the commutator outputs to catch and integrate the spark voltage peaks. Note, due to the nature of sparks, they may reach a thousand volt or so, so if your rectifier diodes (and you probably should rectify these peaks, since they contain back emf sparks) are fried, use 5 diodes in series as one HV diode substitute.
The voltage ratio seems to tend to the extreme in figuera designs. I had a turn ratio p vs s of about 1 to 2, input voltage dropped to 2.5 v (iirc), but output was 25 v (after rectifier with cap),
Would be nice to see some pics. Keep up the good work!
PS. maybe this contradicts what others said, but I tend to use rather less turns on the primary and more turns on the secondary. This causes more current flow in the primary, stronger magnetism and finally better coupling. Just make sure tbe primary won't get hot when unloaded. The higher number of turns of the secondary keeps the voltage high, but should not be  too high, otherwise there is no more current in the output.
Where in 2 coil transformers the voltage ratio is the same as the turns ratio, in the Figuera setup the ratio seems to be exponentional.
marathonman
Quote from: dieter on March 27, 2014, 01:23:48 PM
Dieter;
what we possibly have is two opposing  magnetic fields from two different cores that could quite possibly be canceling each other out even though one is causing the other. once current flows in secondary core lentz law will take place but that seems more likely on the same core not separate cores. if the magnetic fields are equal in strength it seems they will cancel each other out leaving only the electric fields to combine for the next pole peak.....ie SN or NS 50 % opposite swing??????
