0 Members and 62 Guests are viewing this topic.
hanon
Look what I have found about a replication of this generator :
http://maestroviejo.wordpress.com/2013/05/06/clemente-figuera-aunque-para-recoger-electricidad-no-haga-falta-bobina-tesla/
The controller is a VFD (Variable Frequency Drive) from a DC motor  (PWM --> pulsed current)
Please share your thoughts about this info
Doug1
Hanon
Where did you get the image on Reply #97 ? Where you were asking about (To the origin). Maybe you could upload a collection of images and state where they each came from. I only speak English so looking at you last entry I was only able to veiw a couple photos. As far as thoughts go ,it apears or looks like the inductor/s are placed between the faces of the electro magnets not wrapped around a core piece of iron.Not like a transformer which shares a core with other secondary windings. I think most people can gather that from the patent discription. If all the lines of force will travel the air gap then another set of dynamic princeables have to be used like fluid dynamics to tweek the gap and its relationship to the inductive winding sitting between it. A iron core peice between the gap is most likely not needed ,the opposite electro magnets core will attract the lines of force through the space and inductor coil. If the inductor coil current ends up in the opposite electromagnets after passing through a load it will either be additive to the attraction of the lines of force.Or it will resist the lines of force by pushing back with the same force depending on how the n/s electromagnets are wound.Viewing the electromagnet charactoristics the B-H curve would benifit most if it were short and fat. To much waste goes into reaching the peaks of permiabillity when all the desired reaction is in the changing lines of force and cutting them with as much conductor as possible. Sory for the long sentences.I write as I would speak.Ive never had to use periods when speaking.Everyone I know complains about my grammer and spelling.
hanon
Hi Doug,
The main site to download all info about Clemente Figuera (his 5 patents and all historical documents) is: http://www.alpoma.net/tecob/?page_id=8258
Particularly, the picture you refer with the text "To the origin" is the figure from the 1908 patent. This is the direct link to the pdf file: http://www.alpoma.com/figuera/patente_1908.pdf
ALVARO_CS
Quote from: Doug1 on June 10, 2013, 09:13:13 AM
Hi Doug
in the text behind the photos it says one electromagnet is placed between the 2 collectors. And 4 electromagnets with 8 collectors is all that is needed.
Its an inverse way to the original patent, I think.
cheers
Alvaro
Doug1
Thanks Alvero and Hanon
Been a long week.
Have you considered how fast the little comutator gizmo will have to spin to output AC at 50 to 60 htz? It does all seem to be sort of backwards or inverse.
