0 Members and 67 Guests are viewing this topic.
Doug1
Bajac
The term "blown up" is more often a slang term meaning his truck is broken beyond repair.Blown engine or transmission or both.One can even blow up a toilet which is too say you better let the room air out for a while before you go in there. You can blow up a phone meaning people have called it non stop for too long. Of course the last one being someone used explosives and really did blow it up. It's actually best you don't spend too much time thinking about the terminology. It does not work well even here where the abuse began in the south. Same problem with yonder or piece being used as a measure of distance. A real good one is "a coons age" short for a raccoons age what ever the F### that is.
bajac
bajac
Quote from: ALVARO_CS on September 01, 2014, 11:11:36 AM
yes yes
I can do that,
I can feed the dc motor (prime mover) at different power levels (Volts & amps) not only amps.
Will do it with an inductive load (dc motor at output side) in which I can check the RPM, or with a resistor across the output leads.
@Alvaro,
How is the testing going? Did you measure the no load voltage?
I am kind of skeptical about the device due to the configuration and pitch of the permanent magnets and coils. Because the magnetic fields are configured in the same direction, if the magnetic fields cut both sides of a coil simultaneously, the induced voltages will subtract decreasing the net induced voltage.
@Marathonman,
I apologize for the misunderstanding. English is my second language and I learned it while attending college. The relation with my peers was purely technical and professional. I have had some funny situations because I was not exposed to the bad words that a person might learn while attending pre-school and high school. I also have a reduced English vocabulary for cursing. I guess  the reason could be that I have been very busy reading technical books, only. I need to read some novels.
Thanks,
Bajac
shadow119g
No one that has more than one language does not  have to apologize for anything. I can request a double room in German and maybe get breakfast. In France I could get an eclair and coffee with cream. I lived in Paris when I from age eleven to thirteen.
I admire every one of the people communicating in all forums that can communicate in English.
Thank you all,
Shadow
ALVARO_CS
Hello bajac
I was very busy last two weeks, could not do the measurements.
I`ll try to do it next week.
Quote"if the magnetic fields cut both sides of a coil simultaneously, the induced voltages will subtract decreasing the net induced voltage."
not sure of that, because the magnets are in atraction between the two rotors, so the coil is traversed by a manetic "buble" ?
