0 Members and 57 Guests are viewing this topic.
Doug1
Hanon
You continue to neglect time. The time it takes for a magnetic field to reach a number of lines for lack of a better description. The time being partly effected by voltage core size and amperage windings. The dc side is slower then the ac side. Granted it is a measure of fractions of a second. The amount of field or strength or number of lines produced per watts in for the two different types of input will not be equal in time to reach the same level of saturation in the time between pulses of dc and cycles of ac in the model. The induced output will not be equal for the two different inputs. The output would have to equal the sum of the two inputs.
NRamaswami
Doug1:
Posting after a long time..You are correct on patents. There is no patent for a basic principle. However devices that use the basic principle are patentable again and again and again with various modifications as long as the modification results in an improvement over the earlier apparatus...The patents are very clear and unambigous..Principle is very clearly explained in the patents.
hanon
Quote from: Doug1 on February 21, 2015, 08:45:50 AM
Hanon
Doug,
In my last proposal I am suggesting to use normal DC in one coil, and normal AC in another coil of each inducer. I am not saying to use pulsed DC as you seems to have understood. Just normal DC + AC. My scheme in that post is quite clear. We shoudl thnik about the resulting magnetic field strength from one coil (DC) plus the second coil (AC)
For those interested I attach here my last design. I have to add yet the second coil to each side inducers. Work in progress...
Doug1
Hanon
  You might be building a magnetic amplifier. I tried to upload the file but it keeps giving me fits. So here is a link to a declassified paper which gives a pretty good account of them and their history. Make a note of the dates. They were were once called power regulators.You can also look back into some early versions of self regulating generators and dynamo's of the early 1900's.
http://r.search.yahoo.com/_ylt=A0LEVjw1.OlUYakAIaEnnIlQ;_ylu=X3oDMTEzMW0yNTZkBHNlYwNzcgRwb3MDMQRjb2xvA2JmMQR2dGlkA1lIUzAwMV8x/RV=2/RE=1424648374/RO=10/RU=https%3a%2f%2farchive.org%2fdetails%2fMagneticAmplifiers/RK=0/RS=R7.h1h2BrcmtGxwmRFAM9LDu1ns-
Doug1
