0 Members and 62 Guests are viewing this topic.
RandyFL
Hello All
Finally got my 555 and 4017s running correctly...Bit of a delay from surgery and then laziness.
I randomly used 6 100 ohm resistors and 1 50 ohm resistor for the 8 resistor collector connections...
I am using a 12 volt 300 CCA lawnmower battery to power the - + rails
I used two breadboards ( one for the 555, the gate and the 4017s and one for 8 BDX53s and 7 resistors )
results.... :-[
I failed to achieve anything from the home made transformers ( 26 awg magnet wire )
so I used two miniature step down transformers and reversed connected them...
I got 1.5 - 3 volts ac...
I don't know whether to go celebrate with champagne or go drink vodka at the nearest bar...
All the Best
RandyFL
RandyFL
Hello All,
I got the info I needed from reading the previous posts here...
Thanx for keeping this forum going.
My two issues were the power resistors ( to many ohms ) and the thickness and number of turns for the primary transformer wires...
All the Best
RandyFL
NRamaswami
RandyFL
You are way off..
Thick wires have low ohms. Thin wires have high ohms. Resistors have higher ohms than wires.
There is no specificied thickness or turns. This is a concept which will work if you properly do what Figuera disclosed in the patent.
RandyFL
thanx NRamaswami ...
Hello All,
Got a reading in the secondary. Ordered low ohm high watt resistors. I also ordered 14 and 18 gauge magnet wire.
555, 4017s and BDX53s all working in order... Back on track.
All the Best
RandyFL
DIHN
Hello All
AVENGERS, what resistors you used between transistors in front of coils?
