Doug1
Mack
  Mr. Ramaswami  is working on proof of concept for the coil core relationship. It's a part of a device not the entire device. Im sure he would have been pleased as punch if it was all that was needed, plug and play.
  Does the coil/core in question explain how your going to get 200 percent out and how your going to use half of that to suppress the input from the source to get a self sustained run?
  As far as Patrick goes I do not subscribe to him or his ideas. He does a lot of rewriting based on his own assumptions.
RandyFL
I would like to know why Woopy or Kehyo didn't finish their builds...Woopy stated...its for free in the secondary... Bajac is the only one that I know that has built a complete transformer apparatus... but He stated that He took it apart. He has also stated that He is working in parallel by building a solenoid... The math has to be right on this side ( the eight cylinders ( transformers ) have to be firing correctly ) of the fence before the " free " side gives up its secrets... if it has any. " My " basic assumption is that whatever is out there ( if its out there ) will work on a small scale just as well as on a big scale. As far as any " genius " status...I would prefer the " free " status any day of the week...
Cheers
NRamaswami
Doug, Mack:
Without going in to much, what I have done is this..
a. Create a primary..
b. Take a permanent magnet and measure at what distance the permaent magnet does not oscillate in your hands by the EM wave from the primary core.
c. bring the magnet towards the core of the primary so permanent magnet will start oscillating increasingly violently.
d. Identify the distance at which the magnetic oscillation does not increase.
e. Divide this distance by two.
f. Build the middle coil for this distance.
g. Keep the middle coil at half or slightly more than the diameter of the primary core.
h. Wind the coils on the middle coil to prevent the iron rods of opposite poles of primary from crashing in to one another and so build the middle core to be slightly above the primary core size alone.
Results:
a. For a single module the output of middle core alone is less than the input of the primary. But irrespective of the load on the middle coil primary input is constant. Primary does not care whether you load the middle coil or do not load the middle coil. Therefore the secondary is Lenz law Free.  For this to happen one thing must be done but I'm not disclosing it..You can find it in the Patent of Figuera but he feels it is not necessary to disclose it.
b. you continue to add modules. As primaries are added their resistance increases and so input decreases. As secondaries are added their voltage increases and so output increases.
C. Continue  steps a and b above.
Problem with Figuera device is that this requires a lot of iron, lot of coils, and not infrequently the brush of the rotary disc goes. It needs to be very sturdy for long term use. You need multiple modules which costs lot of money.
Within my budget I modified the device and the results were available.
I'm working with a group of like minded replicators and what we are doing and what are the results I cannot disclose without their consent.
It is not impossible to get the center core output on its own to be greater than the input. But certain conditions need to be fulfilled for that. They are so obvious that I'm not going in to them and I consider that disclosure unnecessary.
I'm a very ordinary man without much of knowledge. Until I started I did not know the difference between voltage and amperage. Until very recently I did not know the difference between and implications of connecting in serial and connecting in parallel. So actually when I started I did not know that this kind of device cannot be done. So I ended up listing the conditions needed to create the device and I ended up doing it.
These are the conditions.
1. Primary input should be low
2. Avoid back emf
3. Create Lenz law free output.
Figuera patent does all that and it is very well explained in the patent how to do all this. Unfortunately he is very cryptic. That is the problem. I do not intend to post on this as I have given all info needed to replicate already.
JohnMiller
@ALL
I posted recently (post: #2227)a suggestion on how 3 ordinary single phase transformers can be cut in order to build a Figuera device. Even a single 3 phase transformer can be cut in this way. I ask you all to think on it and say if it seems viable. In case answer is yes, we have an easy way to generate setups like in Figuera patent. The implcation is that we really need to apply all 4 air gaps in order to direct flux as requested.
If anybody is a good programmer of Arduino microcomputer I have advice on what behavior to program in order to  control the primary coils. such a program could help all others to get en easy repliction.
Rgds
John
JohnMiller
Hi ALL:
I found an Arduino program that does exactly what we want in order to controll the Figuera device along two field effect transistors. It resembles the rotary switch signal but along nice sine control via PWM. (I had no time to test it myself up to now.) As far I understand the program you download from Arduino IDE and can start instantly.
http://www.edaboard.com/thread250505.html
