0 Members and 59 Guests are viewing this topic.
SolarLab
Hello jegz,
Normally I do not respond to posts [info provided is only F.Y.I., and on occasion is found to be of value]; but, due to a flight delay, I make this rare exception - time permitting.
Briefly, Symmetric Transformers/Systems (normal) can not achieve an efficiency greater than 100% and fall to near 94% (if well designed and constructed) with no load. BEMF will reduce this considerably when loaded.
Asymmetric Transformers/Systems can achieve an efficiency of greater, or less, than 100% - an example is Bi-Filar wound which can significantly reduce BEMF.
Please see this link, in particular post #7, for much greater detail and discussion:
http://zaryad.com/forum/threads/asimmetrichnye-transformatory-v-sverxedinichnyx-sxemax.8970/
The forum is Russian. If you do not read/write Russian you can use "IM Translator" Firefox Add On and get an English translation - the authors there write very well so the translation works quite good; plus the forum is heavily moderated! BTW, IM Translator is free, can translate a full web page, has three translators, provides a technical Russian dictionary, in-line translation, etc. It's excellent, but not perfect yet (Russian language is complex and a bit difficult, but the people are great - and somewhat nice crazy!)...
A broader OU Theory subject link is:
http://zaryad.com/forum/forums/obschie-principy-ustrojstv-alternativnoj-texniki.136/
And again, some excellent discussion and information...
Must run (fly) - have a very good day!
To quote Red Green: "Remember, I'm pulling for ya, we're all in this together."
SL
Doug1
hanon
Look how the VTA by Floyd Sweet was supposed to be designed...
hanon
And this is how the Magnacoaster by Richard Willis (Patent WO2009065219A1) is described in the patent....
Compare those designs with Figuera's 1908 patent.
marathonman
It never ceases to amaze me how you people can blindly post stuff that has absolutely nothing to do with Figuera's device at all.
Read and digest William Hopper Motional electric field paper. you will find that the Figuera device is a pure BV device hands down. he proved that not only is Figuera's device is NN orientation but that it is a pure BV device with B fields cancelling but are positive and additive. just because the B fields are cancelled does not mean the Electric fields are. they are in fact not cancelled and are positive and additive with the Secondary residing in the space where B = 0 but E fields are alive and present.
this man proved with out ANY doubt 70 years later that the Figueraa device is pure BV in nature. if you doubt him you need to see his credentials before you run the mouth to disagree.
Hanon i know not where you are coming from because the Figuera device is a completely different operation. Magnacoaster uses a ringing effect and Figuera's device is pure BV in design and basically may be the only one of it's kind. it is a overlooked simple fact the hidden BV field.
I really can't understand why no one can connect the dots especially when the dots are so simple to construct. once my light bulb lit the knowledge flowed in freely.
E = B1 X V1 + (-B1) X (-V2) = 2B1 X V1 so basically E2 when B = 0
