0 Members and 57 Guests are viewing this topic.
hanon
Also there are two different manifestations of Lenz Law:
1- Lenz Law derived from a flux linking two coils
: It will create a opposing magnetic field (Binduced) against the change in the original magnetic field
2- Lenz Law derived from a flux cutting the moving wire
: it will appear a dragging force (F_b) which oppose the movement.
A proof of this dragging force can be seen here in a coil perpendicular to the inducer field: Video
Therefore: even in a coil at right angle to the inducer field we will get a dragging effect, although we can skip the opposing magnetic field. But we still have the dragging force against the movement..
Maybe the idea behind Figuera devices was to move the flux lines to cut the wire instead of moving the wire to cut the flux lines. This way you could skip both the opposing magnetic field and the dragging force. I don´t know. I am still learning ...
Doug1
Two wave producers super imposed offset by 90 degrees or overlapped. Independently reaching saturation to retard current independently sharing a single source but also controlled independently. I tried to copy paste the image from the telsa patent for two reasons. One it shows how he found a way around the patent examiners which is amusing. Second it shows better detail. If i were more sure of your historical exposure I would have just alluded to the theory of a double acting steam piston engine.
The inducers are pushing the induced by pushing back and forth against each other they only need enough current to maintain their respective feilds.The point between two opposing fields consumes no power but is the same direction of each other (NN) (SS) so direct linking magnetically is impossible between the inducers.Preventing the activity associated with transformers. If you place any two independent magnets north to south they combine into a single magnet.No good .If you do the same with any two electromagnets you get the same. Then the interception with a secondary or induced follows normal transformer rules, at the expense of supply current. Which has no advantage. Im not big on wasting my time with drawing pictures that already exists.If I were paid to do so I would, maybe actually no I would'nt. I gave you a clear image of two magnets facing each other and the field is clearly seen using iron filings. You can see the way each of the field flow with a distinct shear point between them where all the magnetic lines of force are squashed together in a fraction of the space they normally resided in. How many times have people drawn up something which acts like a normal transformer and got zilch for results. Do you really expect those lemons to give up chocolate milk?Really? Want to toss some formulas into the air showing a singular field? Im sure it is quite accurate but no more relative then the lemon is to cocoa bean. Find a formula to show two seperate fields which alternate in strength never using more then either one at full saturation because the current is adjusted from one electromagnet to the other in part and in succession never going to zero power on either.So in theory you only need calculate one electro magnet at full saturation for one. Then find a formula to give the quality of the magnetic field and it's potential reaction on a secondary or induced winding on a second core in close proximity. What could come out of the induced based on the quality of the inducers field is not at the expense of the inducers or the current which produced the field because you did not link the inducer fields to each other to make a complete path between them they are kept independent of each other. Only the space between the two opposing fields with its shear point and line of seperation is moving to and fro. The difference between these two fields which flow opposite directions (that is to say they still flow N-S but when facing each other N-N it will be seen as opposite flows of flux) it is twice as great as a single field changing direction back and forth.  Im sure you know of or have had some one explain or ask the question" If a south bound train traveling 60 miles an hour runs into a train going north bound at 80 miles an hour what is the speed of impact?" It's not 80 nor 60, it's 140. Consider further will a train consume more fuel going 140mph compared to two which are going one at 60 and one at 80? Lots of variables come into play. trains being pretty far from two magnetic fields pushing against each other .The connection is little more then to help you think in terms of opposition not cooperation of fields.
   Now you speak of a single half wave, I have no idea how you got that.Its far from that.Next you will be jumping ahead to two D cores with a single link between them powered by primaries seperately. Thats not the same thing either. You would still be working off transformer rules by permanently linking all the fields. They cant very well push each other around if they are combining into one.Then the only way to push it around is to use a lot power getting it to reverse direction 50 or 60 times a second.
Another way of looking at it: Take a pipe and place a balloon on each end.Imagine you have placed a portion of air into the pipe enough to make the balloons taught but not expanded. Then imagine you can get a solid piston inside the center of the pipe. If you were some how able to move the piston to one side you would push more air into that side and the balloon would expand while the other emptied. Then push the piston back the other way and other balloon will fill while the opposite empties. You have not changed the volume of air in the set up you just moved it more to one side then the to the other side with the piston. Now what if it was the air that was pushing the piston back and forth by squeezing the balloons one at a time? Still the volume of air remains the same while the piston moves back and forth. Replace the balloons with inducers and replace the piston with the induced. Think of the air as the magnetic field with a point of seperation between the two sides because they are naturally repulsive to each other.
  In the first model the volume of air is static ,it does not change in volume it just gets squeezed back and forth. In the electrical model the electro magnets will not take on much more current then it takes to reach saturation. Once optimal conditions are reached in the quantity and quality of saturation in the cores of the opposed inducers (NN) (SS) they are squeezed more or less to move the field seperation between them so the fields move back and forth between them like the air and piston in the air model. The induced sees a changing magnetic flux but little was required to keep the inducers flux intact after it was made initially because it thinks it is saturated. Between two inducers in total, the amount of maximum flux for one of the inducers is shifted back and forth between the two. These two inducers think they are nearly saturated all the time. Because as the field becomes more in one compared to the other one occupying more flux space then the other even trying to over take some of the core of the other but it cant because two north or two south cant be in the same place at the same time reducing the effective mass of the lesser as seen by its own field. They can be a little closer or further apart depending on strength giving rise to movement between them.
I know some people think you can only generate current if a magnet passes all the way through a coil so both north and south poles are involved. Seems kind of counter intuitive since they pass one at a time and cause a reverse effect of each other on a conductor which still has nothing to do with anything since the inducers are facing opposing directions only to prevent direct inductive coupling to each other while still getting a change in a specified location of induction between them for the induced. Truthfully I dont think your going to be able to come with a formula that will be complete enough to be of much use in terms of output due to the complexity of the cores and materials coupled with an inverse motion of induction by seperation. Don't look for me to do it any time soon for you.
Doug1
How nice of you to offer up a graphic.
On either side of the induced coil place a mirror image of the magnet (N N) Move the coil left and right in the space between the magnetic fields. So the coil is either completely in one of the two fields. Move the coil back and forth. The induced coil sees a field of opposite direction of flow as it passes from one to the other. To maintain the magnetic field requires little expenditure since it is not reversing magnetic direction. The magnetic field needs to change in strength opposite it's counter inducer magnet for stationary model.So as to shift which magnets field is covering up the induced. These models or images and formulas only account for a single magnetic field and sometimes a cooperating set of magnets.Not opposing magnets, so the formula given will not apply. You need to know how much current it takes to maintain the magnetic field of the magnet then split that between two magnets then move potential or current more to one and less to the other and vise versa in succession at the frequency your looking for. If you combine the flux into a single path so they join you will have nothing worth noting.Just another POS transformer.
hanon
Quote from: Doug1 on November 18, 2013, 01:16:27 PM
Thanks Doug for your long explanation. Your post are very dense and difficult to dissect. It is a pity that you don´t use schematics to make easier the interpretation (you know what it is said that an image is worth more than 1000 words)
Here I just post a sketch that represent your idea. Two like poles facing each other and swinging back and forth along the changes in intensity in the electromagnets
As you can see in this scheme there is induction by:
    1-  Induction by Flux linking along the part of each coil transversed by the flux lines
    2-  Induction by Flux cutting the induced wire
The key that in this scheme is that the flux cutting induction to be greater than the induction the induction by flux linking. (the flux linking induction is under the Lenz Law effect and will produce an opposing induced magnetic field which will reduce the inducers strength)
The good part of this idea is that if the flux cutting induction by an N-N configuration will induce in the sense to reduce the inducers field, then the S-S configuration will do it in the sense to increase it because the flux lines in each case have opposite direction.
Doug1
I do believe he's got it. ;D The only way to conserve input is just that. conserve it by not directly coupling the magnetic effects to the output constantly while still getting the change in flux in the induced. Two magnets with an effect on time of 1/4 of the time each= 50 percent used to operate induction at 100 percent the decline is free. I think you'll find reminance can be your friend along with Lenz law if you have enough realistate to keep everyone happy.Now you can think about geometry of pole faces to even out things and the hour glass shape of the core pieces to consintrate force and reduce wire. The electric motor in the home of Mr ya know who,that was not a novelty. It lags and lagging reflective power keeps all the lights from knocking the entire works out of time. The motor is a must have just let it run under no load. Might work better with a weight to function as a fly wheel if too small a motor is used. May even have to start the motor turning by hand if proportions are out of wack.
