0 Members and 62 Guests are viewing this topic.
Farmhand
Here is a picture saying what I think he did. Everything to the left of the dashed vertical line is what he patented or made claims on. What he left out of the patent as many say "something is always left out" would be everything to the right of the dashed vertical line.
Forest, Multiple arc simply means "In parallel". The coil and leads represent an "arc" and multiplying them is putting them in parallel (Multiple Arc) while series connecting them is putting them in a string.
forest
Farmhand,, yes it's parallel but I never thought about it such way. Essentially when we have a load connected to two or more coils then those coils are shunted by each others...interesting....it's just a new look
Farmhand
Yeah Forest, exactly.  :) But we still must be careful to connect them together so as to reinforce each other not with opposite polarities while in phase, kinda thing i think. I'm fairly sure you know what I mean and already understood that, but it is good to say so others might pick up on it.
Cheers
hanon
Quote from: Doug1 on November 22, 2013, 07:01:21 AM
Arc was a type o , ac connection.
  examine the generator closer KK K'K' the gen has two field magnets it;s simple ac generator so why the four slip rings and brushes? Trace out the connections to the annular ring.
  What will be the hard part is to get the fields centered so that the exact place where they reside in the induced is evenly positioned amongst all the sets so when current is shifted between the inducers it happens at the same time with the same amount. A method to test the field strength of each inducer while in place needs to be established. Any difference of sets will counter the effect in the other sets.every electromagnet of the inducers has to be exactly the same in strength and volume. If you have more volume of iron core or wire in half it wont react evenly on that part of the cycle.
Hi,
Then you mean that the connections in the annular ring will reach to a like poles facing each other situation. Is this what you are trying to say?
Doug1
Yes, read page two very carefully of Teslas patent. The generator has two coils on the armeture and two magnets either elctro or perm magnets. The two coils are connected to four flip rings. Making two connections to each side of the generator windings. He is splitting each into two. Then off to his ring converter where they are 90 degrees out in one respect but not in the other by way of the second set of connections. The line of greatest effect whirled about. He says "a line" not a square not a rectangle not a field not an egg, a line. The line is where two like poles repel each other. The line is very thin but it contains the volume of both sets of field lines in a small space which can not become mutually interactive with each other except to shift the line in one direction or the other by virtue of the strength of the magnets being controlled. The direction of magnetic flow for each inducer field is in opposite direction of the other. As soon as the line is crossed or the line crosses the induced the field is 180 degrees reversed from the perspective of the induced. How much quicker do you think it would be to move a fine line between two n facing poles a quarter of an inch back and forth compared to completely reversing the poles in a magnetic core. Think about the energy it takes to reverse those poles compared to shifting them slightly.
