marathonman
This replicator has proven many things i have been saying for quite a long time and is almost there. he credits me for the theory but it fact it is Figuera and the original replicator that shared to me many years ago.
screen shot is a purposely overshot to show the actions of the secondary when the rising primary was taken over to far and brought back on the coil giving the double peak. this is NOT possible with Transformer action.
the Figuera device is strictly a stationary Generator with NO transformer action taking place.
Hyiq is changing the world.
Regards,
Marathonman
marathonman
Look at the Graph belown it shows a magnet increasing the magnetic flux (inward) and one decreasing it's magnetic field (outward). the current is in the oposite direction each time it is pushed in and pulled out just the same as if it were an electromagnet being increased and decreased.
now take the reducing electromagnet to the oposite side of the increasing electromagnet with the core (secondary) in the middle (THE FIGUERA DEVCE). you will notice that the fields are now in the same direction which is what i have been saying for quite a many years. when you reduce the electromagnet on the oposite side of the increasing electromagnet the electric fields are in the same direction being positive and additive. the magnetic fields will never combine and the Lenz law will always keep them separate at all times but AS I HAVE STATED FOR YEARS THE ELECTRIC FIELDS ARE ALIGNED AS SUCH WILL COMBINE TO FORM ONE FIELD BEING POSITIVE AND ADDITIVE.
as long as the magnetic field pressure is maintained it will act just like a standard generator high intensity field. the primaries are reduced to get the sweeping action of the secondary lenz field across the electric fields formed by the primaries. this is the realitive motion of the primaries inducing motion into the secondaries.
when the primaries polarize the secondaries with a load attached (mandatory) and current begins to flow a second field will form in the secondary (Lenz's Law) that will oppose the first field. it is this opposing field that is sandwiched between the primaries that is swept from side to side across the secondaries sweeping the electric field giving the illution of motion of the secondary to the electric field.
as long as the pressure is maintained between the primary North face electromagnets the output will be a constant AC output flipping the poles every rotation of part G from the sweeping action of the primaries, one reducing while the other is increasing. if for any reasom the magnetic fields of the primaries are reduced to low induction will fail and the output will be reduce to just that of the rising electromagnet.
this is the very reason why the reducing primaries are reduce to just clear the secondary then back to full potential.
Regards,
Marathonman
marathonman
Part G being an active Inductor changes the Magnetic flux to current ratio on a continuous basis therefore creating ongoing increase or decrease in current flow.
as the brush rotates around the Inductor windings on either side of the brush are constantly changing either adding or subtracting which according to Faradays laws of induction causes an EMF to form in the circuit and according to the Lenz Law it will oppose the original current flow.
in the graph below it shows coil A with a few winding and if we have a given amount of current flowing through the coils it will produce a given amount of self induction that opposes the original current flow.
now in coil B we have an increase in the loop count with the same given current flow. what just happened is the amount of inductance just changed and according to Faraday's laws of induction all that is needed for EMF to be produced is a change in magnetic flux which just happened. now if we do this on a continuous basis we have an orderly rise and fall of magnetic flux which is an orderly rise and fall of current flow because any increase or decrease in the magnetic flux will in fact according to Faradays Laws of induction create an EMF and according to the Lenz Law it will oppose the orighinal current flow.
so precisely as Figuera intended as the brush rotates we have the most efficient way to control current flow in the primaries  increase and decrease in the magnetic flux to current ratio that controlls the current flow to each set of primaries in complete unison. when one is increasing in winding count the other is decreasing in winding count at the positive brush.
Self Induction can and will control current flow plus using the stored and released potential in a positive manor.
Regards,
Marathonman
marathonman
The Figuera device uses an active Inductor for part G that changes the magnetic flux to current ratio which according to Faraday any change in flux produces EMF and according to Lenz it will oppose the original current flow. along with that it stores and releases potential at a specific time to add the rising primaries to maintain the pressure between the primaries to sustain ongoing Induction.
the primaries are reduced and increased to induce motion into the secondary and once current begins to flow in the secondary and the load a second field will form according to the lenz law that will oppose the original current flow. once this happens the primaries and the secondaries part ways and it is just the realitive motion of the primaries that induce motion into the secondaries. after this polarization no other time is the potential circulating in the inducing system is tranfered to the induced system. they are essentially two separate systems from then on just like a standard generator system.
as the brush rotates the current through the primaries are reduced and increased 180 degrees out from each other causing the Electric fields to be in the same direction being positive and additive. the primary and the secondary cores are separated to stop eddy currents and hysteresis from interferrring from the action of the AC in the secondaries to the primaries.
with the lenz field from the secondary sandwiched between the primary fields the primaries are raised and lowered in intensity just to clear the secondary coil then back to full potential while the other is reduced.  in this action of reducing and increasing  the magnetic fields stay opposing while the Electric fields joiin as one. in this set up the peaking of the primaries need to be symetyrical, meaning the peak of the primaries needs to be the same or induction will be lost thus reduced to just the rising primaries.
there are two primariy facing each other being north face opposing electromagnets with the secondary located between them with an active inductor used as the controller controlling the current flow through the primaries.
if you do not have your setup like this or your coil core arangement is different then congratulations you are NOT working on the Figuera device 1908 patent. anything other is just that something other than the 1908 patent and i wish you luck in your pursuit.
this thread is according to my knowledge following the 1908 patent of Clemente Figuera patent in Barcelona Spain in 1908 that powered his house lights, a 20 HP motor and all the street lights around his house.
Regards,
Marathonman
marathonman
The reason no one is getting an output from their cores isfrom the inverse square law that states the intensity will be reduced at the square  of the distance.
Also through my own tests on the bench it showed that a magnetic field will only project out the core the same length as the core it self. a 3 inch electromagnet will only project a field out three inches.even when saturated it only hit 3.2 to 3.3 inches which is not near enough pressure for an output if the secondary is the same length.
Make your primaries twice as long at no less than a 2 to 1 ratio and watch your oyster open up.
Regards,
Marathonman
