Simple Free Energy Effect Discovered
Started by aether22, October 07, 2012, 07:39:45 PM
Neo-X
First of all im not arguing in you infact i believe on your theory. Increasing the velocity of electrons has a exponential impact on the zero point energy but its hard to prove using your experiment because using thin wire with high current just only to increase the velocity will only  reduce the overall efficiency of the circuit. Theres a simple way to increase the velocity, its by using high voltage. Electrons is like a water in a pipe. If u increase the pressure on the water, the velocity of water flow is increased. If u read the documentation of patric kelly of free energy devices in chapter 3 don smith device, it was said that increasing voltage on the primary has a exponential increase in power gain on the secondary. I would suggest you to read that docu. Its very informative and it will help u alot in building ou devices.
norman6538
Has anyone tested this two different wire coil stuff? I hope to get to that today or tomorrow.
Like he says - its a simple test.
Norman
crazycut06
Hi aether22,
Have you tried using same inductance of thin/thick wires instead of same length, as TK mentioned some post back, maybe because of unequal inductances thats why you get induction?
Cc
Magnethos
Quote from: Neo-X on October 09, 2012, 01:38:24 AM
Imho there is a trade off here. Current is the amount of electrons passing in 1 second. If you use thick and thin wire with the same length connected in series, the electron passing in thin wire might increase in speed but it will reduce the density of electrons flow in the wire. On the other hand the electrons on thick wire is slow but has a higher density. So the total amount of current and ofcourse magnetic field is equal that will result in zero mutual induction.
It's only an oppinion, but I think you're correct if you see that example while using conductive current because this power has 2 components: amperes and electrons.
I say you this because I remember I read somewhere about a Tesla's experiment with pancake coils where he used 1 thin wire and 1 thick wire. The result was an increase of about 10 times in the electric field. But I think Tesla did that using capacitive current.
norman6538
I made the two sized wire coil with first layer 60 turns on a nail with the large wire clockwise away  and 60 turns of the small wire counter clockwise away
and when powered the nail attracts a paperclip.  So I do not see the canceling magnetic
field.
A compass test shows that the large wire dominates because the compass shows
the same polarity when the large wire is powered and both coils powered. And
the small wire powered make the opposite compass deflection.
I wish someone would get the proper results and report that instead of this.
If we had a no Lenz generator we'd have plenty of cheap electricity. There are no Lenz
patents but nothing I know of in production.
Norman
