Graham Gunderson?s dragless generator patent, Lenz law violation !
Started by hartiberlin, July 27, 2006, 04:45:33 PM
Overtone
Whoops. Error.
I meant to say that given what we have learned since the original patent application was filed, any attempt to build this device, by an individual, is extremely unlikely to succeed!
Should have had more coffee before previewing my earlier post :).
Mark
acp
QuoteI posted back last October that the application has been superseded. A new patent application will cover factors we discovered are necessary for this invention to exceed unity.
Cores that will work are, as some have suggested, expensive. They must have little known characteristics. They must be processed using very costly equipment. This invention cannot exceed unity otherwise.
Therefore, sad to say, it is extremely unlikely that any attempt to build the device by individuals is almost certain to fail.
To repeat, the first prototype worked and exceeded unity.
Commercial variations are under development.
For reasons of international patent law, such as Taiwan and South Korea, where publication instantly negates patentability, we will not reveal the critical additional information until the second patent application is published.
Mark Goldes
Chairman & CEO
Magnetic Power Inc.
Ha ha ha,  you are so funny..........
MeggerMan
Hi Marcel,
Could be the inventors are getting twitchy about people replicating their baby?
I have just done the simulation again in Femm to check my comments I made previous to you and it looks like I gave you the wrong info or not all the info.
The coils can indeed be connected in series, but the pulse does need to be AC.
To achieve this requires a "H" bridge of mosfets to allow the coil supply to be AC.
This will give the greatest flux change.
Saying that though, to simplify things you can do as I suggested before and use a push-pull DC pulse applied to the two sets of coils to the right and left of each magnet.
I think what Mark is trying to say is that the balance of current, magnet choice and core material are all critical to this working at over unity.
From my simulations, it can be seen that only a very tiny current and voltage is required to get the field to switch (20mA @ 0.5V) and anything greater will saturate the core.
Using a magnet too powerful for the core material, will yes, saturate the core.
Also try using ceramic 5 or ceramic 8 magnets to start with.
I suspect Neo magnets are too powerful for the core material.
The good thing is that Mark's company will be buying off the shelf cores just like you and I.Ã,  Metglass make them, we use them.
Hi Mark,
Given that you cannot give any details about the new patent, can you at least say what level of over-unity you have achieved?
Does the core material drop in temperature as per the MCE theory?
http://emwiki.info/MEMM
How long before you are ready for a production product?
RobÃ,
neptune
....and the silence was deafening. Can anyone else hear the crickets chirping ? Just yet another Bullshiner then......
Overtone
Hi Rob,
Hard as it may be for folks here to believe, I hardly ever see this forum. We are extremely busy.
Sorry. No technical information will be released except in patent applications.
If all goes well, we will provide potential licensees with pre-manufacturing prototypes later this year.
We have no control over the time it takes them to gear up for production.
There are also parts required which are not presently mass produced as they have no existing market. That factor is also one over which we have no control and it may well slow up production, although I would think small quantities of self-powered generators might be in the market by the end of this year.
Since development is still much slower than it might be with additional funding, all estimates are subject to change. Adequate funds might be en-route. If, and when, they arrive we will be able to accelerate development.
At this point it is all engineering...
See the attached Press Release.
Mark
