Naphtalen in your gas tank ? 30 % more mileage ?
Started by hartiberlin, July 29, 2006, 04:16:12 PM
pg46
Yes, I wouldn't want anyone to put too much weight into my poor results until I tighten up some loose ends in my testing methods. I will look forward to trying more tests later on. It may be a while before I do so probably, so in the meanwhile I will look forward to hearing about the experiments of others.
all the best,
TheOne
its not a PCV its the CONDENSATOR connected to PCV pipe :)
Walter Hofmann
Quote from: pg46 on August 02, 2006, 09:07:37 AM
First Test Run-
I have a real efficient Honda motorcycle with a 100 cc engine. I did previous trial mileage runs(last year and today) with regular gasoline of 91 octane and I get a real nice 67.5 kms/lt Like I said, its a very efficient little bike.
The bike has a 5 lt fuel tank and so I crushed 1 mothball(nephtalene) and dropped that into my tank. I ran the same distance and same speeds on the same stretch of highway as the other tests.
With the mothball in the tank I registered 68.5 kms/lt
No earth shattering difference on my vehicle but maybe for others it will be dfferent for their engines and their fuel types.
Maybe the mothball hadn't disolved and mixed properly yet before I took off on the test run, I'm not sure. Will have to try it all again before making any conclusions but thats my initial results.
Hi,
I tested how fast the mouthballs pillsvdissolve in gasoline and it took about 3 hr till it was disoolved the samething was if the pills was crashed. I did put the 10 pills in my full tank on the evening let it stay over night and can say that on the next morning the drive to the jobsite was allready exciting but neede to get use to the higher iddle speed of the engine.
But was I also found out is that in the european gasoline there is allready naphthalene used maybe this is the reason if the results in europe differ against the results here in the US.
I am still driving on the tank filling and be on mile 200 where the tank gauge shows still half full. ( normaly at 230 miles the tank is empty) I will find out and poste it how many miles I get out on the end if I fill up again.
greetings
walt
TheOne
aarnold
Hi friends,
today I bought some naphtalen. I put gas on my car (renaul megane 99). Bought some gas in a bootle too do dissolve the naphtalen. My car made in this last time 440.8 kilometers with 51,06 liters of gasoline (8,63 km/l). I put 15 mouthballs in 1 liter and I'm waiting to dissolve. I'll make this test and a week by now I'll refuel my car and see the results to post in the forum.
My friend that is a mecanic told me that the naphtalen creates a type of "gel" that can obstructs the injector peak. So I'll try to tell you the results..
thanks
Augusto
