Crystal Cell Research
Started by plengo, October 29, 2012, 06:08:15 PM
Allwest
Quote from: ibpointless2 on February 26, 2013, 07:14:03 AM
I've slowed down on the Crystal cell research. All cells but one or two lay around doing nothing. The only cell that is really doing anything is my 5 foot tall crystal cell that powers the LCD clock. The clock was running fine til this month in February when the clock face started to go dim and I assume the cell was finally dying.  I kept it going till the clock face would go blank, but it never did. The clock face regained its brightness but now it was off by 20 minutes. It remained at full power for a few days so I reset the clock back to normal time. A few days later the clock started to loose power again and fell 20 minutes back again, and once it regain power i reset it back. This is the third time so far that the clock looses power and falls 20 minutes behind, every time i set the clock 4 to 5 minutes ahead of the computers time. This is odd because when a normal battery dies it goes dead and won't recover like this cell does.
Right now i'm just waiting for the cell to die so I can pack up work and be done with it. Just when I think the cell is dying it comes right back to life. Even though I think i know how the cell works, sometimes a cell still has something to teach me.
IB,
Does your pipe cell have the ends open?
plengo
@Allwest,
I am stating to understand how your cell can have such high amperage and go up as you use it. It has to do with the oxidation layer formed on top of your Magnesium because of the acidity of the Chilli Pepper sauce.
Your cell indeed dry can be very powerfull. Do a test, make a very light solution of Epson salts like 1 tsp with 50 ml of water and added a few drops of that to your cell and see the results.
It will sky rocket the voltage and amperage every time.
@IBpointless2,
don't give up my friend. There is way much more to it than you think.
Fausto.
Allwest
Quote from: plengo on February 26, 2013, 02:28:21 PM
@Allwest,
@IBpointless2,
Fausto.
Hi Fausto,
This affect happens to my cells even when I do not use chilli powder
I have done a lot of study on this, not certain yet but, the shorting out of any cell causes heat, and heat makes this cell rise in power (with limits as you have found out),
Test conclusion- I get a longer time of power going up with thick mag when shorting out cell than with less thick mag using the same surface area,
Test conclusion- I can get the power to keep going up if I cool the mag
So my humble opinion is that the Allwest cells creates its own energy by heating itself up, until the two different metals have equal temperature
I am creating some kind of self generating thermal electric power,
The normal TEG device does not act this way, it has to be heated and cooled to gain power,
With the Allwest type of cell, all you have to do is cool, (I think this is a huge thing)
You should try this and let me know your finding
Best of luck
Note: The reason why the thickness matters in the mag, is because its mass takes longer to come up to the same temperature as the copper when shorted out
Also, another note, when you make the flat copper mag cell, place copper on both sides of the mag and you will get almost double the power
Allwest
Fausto,
From your videos I see you are making great progress on these cells,
One thing to note on forming these cells that I have observed, when the cell finally drys and reaches 1.47 volts resting then they are fully formed
This number keeps coming up on each cell once it has completed forming, not sure why yet, but it comes up very consistent
And then you know it is ready for the next step
Best of luck
One protection treatment of the mag that looks very promising (Dip the mag in H2O2 and stain the mag black with lighter flame) I believe this adds Nano carbon film that protects mag and adds to the power transfer)
Best of luck
hartiberlin
Hi Fausto and Allwest and All !
Very interesting results you are getting !
Great work !
Well,
when Walter Hofmann and me worked on the Zamak alloy- graphite-saltwatercells in
2005, we also had some kind of Zinkcloride crystal forming in the layer between the
Zamak alloy and the graphite.
This crystal also did grow and form some kind of PN layer
between the graphite and the Zamak.
This PN layer is then like a big diode which can rectify all different kind of wavelength
and might also rectify lower wavelength heat radiation or just the environmental heat
inside the cell...
Probably the same is true in your cell Fausto, so when the crystalls have formed on the Magnesium
metal it is mostly shielded from further fast destruction and the crystal layer between the copper
and Magnesium can form some kind of PN diode layer and extract electricity by rectifying heat or
RF waves.
in 2005 the problem with the Zamak metal was, that it was still slowly decomposing because
of the NaCl salt in the water and thus thus these Zinkchlorid crystals always did grew bigger until
all the Zamak rods were decomposed.
But they formed some nice clear transparent crystals.
Some old videos and some pictures you still can find here.
http://harti.com/walt/
Hope this helps.
Regards, Stefan.
