Friction heater running in my house
Started by oilpiggy, October 31, 2012, 02:25:24 PM
Bruce_TPU
Quote from: oilpiggy on January 07, 2013, 11:58:24 AM
Hello everyone,
Well I am rebuilding the heater in my house one more time :o The dang thing keeps getting so hot that it keeps burning up the oil >:(
I have a few ideas to try.... I am going to slow down the RPMs and run fewer discs and maybe allow more oil pass through between the non moving discs ;)
lol you know what they say practice makes perfect... 8)
Hi Gabriel,
Motor oil is designed to run at about 212 deg. F.  Canola oil has a flashpoint of 620 deg. F.  If you were at 300 deg F. before, Canola oil may be fine, as long as you don't go past say..570 deg. F, for safety.
Slowing the RPM will of course reduce said input power greatly, not a bad idea if you can still maintain the same temp.
Cheers,
Bruce
oilpiggy
Thanks Bruce,
I will look into the Canola oil
I don't have a way to get a temp reading from in between the drive discs, so I am not sure how high the temp is getting. I can only get the temp off of the top of the oil in the core. The smoke temp of the oil I am using is 450F and I am clearly smoking it,... it turned it into a dark brown sludge. ??? :o
I really just don't want to use anything but 100% non toxic easily made oils. {at lest for now}
I will make my mods to the core and take some pics and a video then post them in the next 48 hours.
I am still working on the tooling for the testing models as well.
But I must keep my house warm first and foremost so the one for my house takes precedence. :D
hartiberlin
Hi Gabriel,
well done.
What is the distance from disc to disc ?
So they are magnetized ? North to South ?
Does it also work without magnetosation ? Did you test this yet ?
Do you also put something into the oil additionally ?
What kind of oil (brand and product number) did you use until now ?
Why are you so sure that you don´t produce any cavitation effects there ?
When did you get this overunity heat when you changed what parameters ?
( You probably built the first prototypes with not so much heat output as now, so
you probably know, what makes it now much better ??)
Many thanks.
Regards, Stefan.
oilpiggy
Quote from: hartiberlin on January 07, 2013, 11:28:10 PM
Hi Gabriel,
well done.
Many thanks.
Regards, Stefan.
Hello Stefan,
And thank you.
{Q} 1) "What is the distance from disc to disc ?"
{A} 0.0625
{Q} 2) "So they are magnetized ? North to South ?"
{A} Yes they are but only very lightly, they are set up in N,S,N,S
{Q} 3) "Does it also work without magnetosation ? Did you test this yet ?"
{A} Yes it does work very well without magnetizing them, on my first testing I ran both setups but with the magnetized discs I got a few more degrees out of the heater.
{Q} 4) "Do you also put something into the oil additionally ?"
{A} I only use 100% organic soy bean oils.
{Q} 5) "What kind of oil (brand and product number) did you use until now ?"
{A} I sill am using the same oils but I looking into using refined white mineral oil. It states that it has a smoke temp of 750F but we will see.
{Q} 6) "Why are you so sure that you don´t produce any cavitation effects there ?"
{A} My design is in such a way to not allow for and micro vacuum or any void to be produced as it runs.
{Q} 7) "When did you get this overunity heat when you changed what parameters ?
{A} On my 2nd build is when I got this Friction heater to work as it is. I had to change everything from my 1rst build, it when into the scrap bin.
{Q} 8) " You probably built the first prototypes with not so much heat output as now, so you probably know, what makes it now much better ?
{A} I have learned a lot from this build from the start till now.... and I am still learning. I could make a book from everything I have learned at this point.
Thank you
Gabriel
