Friction heater running in my house
Started by oilpiggy, October 31, 2012, 02:25:24 PM
Quote from: oilpiggy on January 10, 2013, 03:32:15 AM
{Q} 8) " You probably built the first prototypes with not so much heat output as now, so you probably know, what makes it now much better ?
{A} I have learned a lot from this build from the start till now.... and I am still learning. I could make a book from everything I have learned at this point.
Thank you
Gabriel
Hi Gabriel,
yes, would be great, if you could write an ebook and sell it or just give it away freely, what you like...
if you have the time for this.
Probably  you still want first to finish your build completely for youself and heating your house with it.
You new build looks great !
Regards, Stefan.
Quote from: oilpiggy on January 10, 2013, 03:56:59 AM
Here is the new build  8)
http://www.youtube.com/watch?v=RbuZRn9duYE
Well done Gabriel,
but why does it now draw 860 Watts ?
Didn´t you say that the old model was just drawing only 100 Watts ?
860 Watts is a lot of power, if you need to produce this
during wintertime via solarpanels and the sky is overcasts...
Many thanks.
Regards, Stefan.
Bruce_TPU
To compare efficiency, I found the following numbers.   3-ton Goodman heat pump.  The kw's are for the outside unit only.
60F, 2.86 kw
50F, 2.75 kw
40F, 2.64 kw
Gabriel's Friction Heater
.860 KW
Cheers,
Bruce
Paul-R
I am interested in the magnetisation, and if there is a unipolar
(or  homopolar) generator effect happening.
Presumably, the oil is non conductive. Have you tried running the
equipment with conductive salt water instead of oil?
500W no load electric motor consume , 600W load electric motor consume :
the difference means heater consume as load ergo : 100W ,
this is your calculation,oilpiggy - or not ?
wmkr
         CdL
p.s.: oilpiggy wrote about 120sqm heating area and calculating with 20 ° temperature difference and conventional
        floor/wall/roof/window/door isolation I would estimate the heat energy consume with  10KW per hour
       source: http://www.sonnenkoenig.ch/halogenstrahler/asetid/824/product/junior.html
       in red:"Waermebedarf" heat calculation
