Single circuits generate nuclear reactions
Started by Tesla_2006, July 31, 2006, 08:15:00 PM
0 Members and 56 Guests are viewing this topic.
aleks
Quote from: pese on May 06, 2008, 05:20:28 AM
Brems-Strahlung
http://www.datasync.com/~rsf1/bremindx.htm
Pese
Thanks for the link. Unfortunately, it's pretty hard to get all these papers for a science neophyte, so this compilation is pretty useless. What is strange is that the last article is dated 1986. Two decades of silence in this area of research? Pretty suspicious.
Regarding overunity, it should be noted that one when studying Bremsstrahlung should take a note on second order effects: e.g. acceleration of paricles and shift of EM field energies standing nearby to the event of Bremsstrahlung. Mainstream physics may be simply blind to study these second order effects (due to conservation of energy - nobody will even dare to question it).
It seems that at high voltages (20kV and above) Bremsstrahlung produces x-rays due to nuclear electron shifts (what a surprise! :) ), so such voltages should not be used in development: just a warning.
Also note that both acceleration and decelleration causes Bremsstrahlung. I have not found any info on side effects of acceleration Bremsstrahlung: could be also interesting.
Koen1
What's with the Brems-strahlung?
Perhaps instead of just dropping the term, someone could just use words to
tell us what in particular they appear to want to say?
So you can decellerate moving 'free' electrons and obtain radiation emissions.
That's not new, is it?
But that does not really appear to be what happens here...
After all, the "Brems-strahlung" energy should amount to that lost by the electron
in motion. That does not appear to explain the excess energy released
in this system...
But I may just be missing something, of course ;)
aleks
Quote from: Koen1 on May 06, 2008, 06:44:45 AMThat does not appear to explain the excess energy released
in this system... But I may just be missing something, of course ;)
This is what energy conservation dogma says..
But take a note on power spectrum plot of  Bremsstrahlung event:
http://en.wikipedia.org/wiki/Bremsstrahlung
Energy at DC (w=0) is infinite. I'm sure mainstream physics can't do anything about that because quantitatively it means nothing, but if you add a bit of imagination you'll understand that it looks exactly as a singularity and the qualitative result is not what quantum theory can even predict. So, I'm giving my understanding: on Bremsstrahlung event a singularity is created which can be defined as DC acoustic wave or DC EM wave (previously I've posted my idea that electromagnetism and acoustics-kinetics unite at DC frequency emission). X-ray radiation which interests mainstream science in Bremsstrahlung is only a secondary order effect. I can imagine that other second order effects may stay unstudied - and they are exactly the effects many here strive to achieve in overunity quest. :)
Koen1
Ah, ok, now I see your point.
Thanks Aleks! :)
Need to ponder this some more...
MeggerMan
Quote from: AbbaRue on May 06, 2008, 04:36:58 AM
Device #3
I built a device based on the Correas'  Abnormal discharge tube about 2 years ago.
At one point I measured an output 5 times as high as the input.
An interesting observation I made is; no mater how much current I drew from it the input never went up.
So I concluded that I was always using only a fraction of the actual output for my loads.
The output was AC and varied between 700 and 4000 Hz.
Is this based on the Russian Chernetsky device?
I have seen this on the Equinnox channel 4 programme "It runs on Water".
Do you still have the device and are you able to still run in?
It would be useful to see a picture of it.
I was wondering if there might be a link between this device and the TPU, the reason being is that when the core was cut through the inside looked like black carbon. Could be carbon impregnated foam. Is it possible the carbon toroid was wraped in two loops bare copper wire and a pulsed current applied across the two loops that would arc through the carbon toroid.
The collector loops would provide the output.
regards
Rob
